Misfiring and no cel
Old Jan 30, 2010 | 11:45 AM
krisl_85's Avatar
Default Misfiring and no cel
Is there anyone living in the Miami area willing to swap coil packs with me so that I can see if mines are bad? I already did a compression test, changed plugs (oem), bought used injectors on this forum, which the seller said were good since he removed it to go turbo, and I also tried the map whack and zip tied it, but it didn't do anything. I did move the coil packs around and the misfiring did get worst, but that could just be a coincidence.
At first there was a cel for all cylinders and random, I later found a vacuum leak and reset my ecu. Now the car is still misfiring but the cel hasn't come on.
If anyone can help please let me know. Thank you.
Old Jan 30, 2010 | 11:55 AM
captainbk's Avatar
Have you read any pending codes?
Old Jan 30, 2010 | 09:51 PM
jamesk's Avatar
do work
Old Jan 31, 2010 | 10:22 AM
spectacle's Avatar
do a leakdown test
Old Feb 1, 2010 | 05:16 AM
CHRIS_HONDA's Avatar
Check the knock sensor
SteelCoyote
Jul 17, 2015 11:04 AM
ALFYonso
Feb 11, 2011 12:07 PM
Jermizzle
Aug 5, 2009 09:48 AM
S2GD_up
May 22, 2007 07:32 PM
