Misfire
Old Feb 23, 2010 | 07:04 PM
s2kNORcali's Avatar
Default Misfire
Last week I pumped gas at shell. Most of the time I go to Chevorns. A days later my CEL popped up (P01399 and P0301 once awhile) Random Misfire. I thought it was bad gas. I pumped a full tank of Chevorns gas the next few days. CEL still popped up with same code. My car is fully stock nothing done to it.
Last NOV i had the same CEL but i had a valve adjusted and it fixed the problem until NOW.
symptoms: It idles pretty low <500rpm sometimes and it wants to die when I'm at a full stop but doesnt. I clear the code but after 3 starts it will pop up again.
Things I done so far is: Change sparks plugs, switch around the coil packs, NEW MAP SENSOR (did the map wack with the old one didn't do anything)and that's about it. Same CEL.
3/4/10: I bought used Coil packs and injectors with >25K from a running s2k. Drove for about 100 miles. Same CEL
3/17/10: well, i finally took my car the a shop. They did a compression testing:
(95, 210, 215,215). My compression in cylinder 1 was really low. Then they did a leak down testing found out my exhaust valve are leaking in cylinder 1.
What they said next was to take out the head and inspect it more. I would probably need to do a valve job. They quoted me $2,000 for the job.
How much does it usually cost? I remember some people updated the valves and retainers with AP2. I'm not sure.
What should i do next? Thanks
Old Feb 23, 2010 | 07:34 PM
Slows2k's Avatar
Let is run longer for the P1399 temp DTC to turn into a permanent P300-304. You can't isolate coils without a specific cylinder code stored.
Old Feb 23, 2010 | 07:48 PM
s2kNORcali's Avatar
The CEL is now P0301 and P1399.
Old Feb 23, 2010 | 07:51 PM
Slows2k's Avatar
Swap #1 injector to #4, see if the missfire moves
Old Mar 5, 2010 | 07:50 PM
s2kNORcali's Avatar
^ I did the swap. I also even bought 4 used injectors and coil packs from a running s2k with <25K on them from a running s2k. Which didn't even do anything. Same code. It does run smoother. But same CEL P01399 and P0301.
What can I do next? Don't want to take it to honda dealer.
Old Mar 5, 2010 | 10:32 PM
Crisgo's Avatar
Unless its a wiring issue to the problem cylinder coil pack then I'd do a compression test then a leak down test if none of the plug,coilpack, and injector switching made a difference in the problem cylinder misfire
Old Mar 6, 2010 | 04:05 AM
Slows2k's Avatar
Cylinder leakdown test is next.
Old Mar 6, 2010 | 02:45 PM
s2kNORcali's Avatar
will do that and report back. Thanks.
Old Mar 18, 2010 | 03:35 PM
s2k aok's Avatar
surprisingly i had those codes pop up the last two days. had 300, 303, 1399. yesterday i had 300, 301, 302, 303, 304, 1399. never had any codes when i was supercharged or na vafc tuned, unusual how i got a code now, researched it yesterday and found nothing conclusive but replacing single parts at a time to isolate the problem...
Old Mar 18, 2010 | 05:24 PM
turbo_slug's Avatar
since you already know that an exhaust valve is leaking, there isn't much left to do other than fix or replace the head?
