Trunk Leaking
Old Feb 26, 2010 | 08:26 PM
Edberg's Avatar
Default Trunk Leaking
It's gotten to the point that it's rusted a few holes in my trunk, I can't seem to make it leak by spraying water at it from all directions, just after long heavy rains. Anyone know where it could me coming from? It's not that black vent.
Old Feb 27, 2010 | 06:35 AM
jimi's Avatar
https://www.s2ki.com/forums/index.php?showt...0&#entry9854068
Hope this helps
Old Feb 27, 2010 | 07:30 AM
s2k aok's Avatar
good find, that guy did a great write up.
Old Feb 27, 2010 | 10:41 AM
Edberg's Avatar
What should I do about the holes in the trunk?
Old Feb 27, 2010 | 02:29 PM
Mark355's Avatar
Do AP2s have this problem?
Old Feb 27, 2010 | 10:58 PM
S2K1DAY's Avatar
I had wet carpet in the bottom of my trunk. I never stripped the interior, but I don't have holes all the way through. My spare tools have spots of rust on them though.
Old Feb 28, 2010 | 11:02 PM
S2k Eire's Avatar
I had about 3 inches of water sitting in my boot after the snow and ice melted from the car, turns out it was getting in from the aerial mount, you will need a circlip pliers or similar to unscrew it from outside the car, apply some black silicone to the seal and put it back together.
OP - with holes that big Id imagine cutting out the boot and welding another one back in could only save you, dont forget to treat the welds straight away to prevent the same thing happening again.
Old Mar 1, 2010 | 07:24 AM
jeffbrig's Avatar
There's a great link in the FAQ showing common leaks. Some people get leaks around the vent behind the bumper cover. Another common one is clogged drains on the sinks at the edges of the convertible top - they overflow into the trunk. I had the slow/clogged drain problem, it was only apparent during a hard rain.
Old Mar 1, 2010 | 10:32 AM
Edberg's Avatar
It must be that, I discovered it today when washing my car. Whenever water runs down the left side of the convertible top water starts to fill the trunk. I can barely see exactly where it's coming from so I have no idea how to fix it unless I remove the top or something/
Old Mar 10, 2010 | 12:41 PM
Edberg's Avatar
It's dripping down from here somewhere, left side of the trunk behind the carpet.
Any ideas?
