Moddiction is now offering a powder coated aluminum S2000 engine heat shield. This is great for cleaning up the look of the engine bay while also blocking hot air from reaching the intake filter on many intake setups.
Installing is as easy as removing 2 pre existing bolts, putting heat shield on and bolting down using the supplied stainless steel bolts and washers into the vtec solenoid. 5 minute install.
This is a perfect match for the K&N FIPK intake as well as many other intakes available and even the oem airbox.
It is offered in textured black, wrinkle red or textured blue.
We also have the ability to do textured silver, wrinkle blue, wrinkle green and textured white. Contact us if wanting one of those colors.
These are for sale for $69.99!!
When checking out please make sure to select the USPS Flat Rate shipping option as other methods come up as much more expensive!!
No problem man! I'm really happy it has held up fine to daily driving in 100 degree heat and everything. When I put this and my AUT cooling plate, all the "shuttering" when pushing in the clutch on hot days go away. So I know it had to help some. The carbon is still sticking very well also.
