Sponsor S2000 Engine and S2000 Drivetrain Deals Sponsor deals on S2000 engine and S2000 drivetrain products
Fumoto Oil Drain Valve - Easy Oil Changes, No need to jack up your car!
Old Aug 23, 2010 | 08:39 PM
JS2k.com's Avatar
Sponsor
Wink JS2k Oil Drain Valve - Easy Oil Changes, No need to jack up your car!
About the JS2k.com Oil Drain Valve
Introducing the easiest way to change your oil with no need for tools or jacking up your car!
Just watch the video below to see how easy your oil changes will be.
Benefits!:
* Never jack up your car again to change your oil
* No tools needed (for future oil changes)
* Winter and Summer friendly oil changes!
* Garage-less friendly oil changes!
* Never pay anyone to change your oil (pays for itself in one oil change!)
* Never strip a bolt
Detailed:
Our Oil Drain Valves make oil changes so much simpler. Install this valve instead of your drain bolt to drain your oil with no hassle and never a worry of a frozen or stripped drain bolt. These valves are double sealed to prevent leakage and years of service. With its forged brass and stainless steel composition, it resists corrosion from the water and mud that it may be exposed to. The lever locks to prevent accidental opening of the valve.
For some vehicles, like the S2000, you will never need to jack up the car to do an oil change again! Just slide a drain pan under the car and release the lever! This makes oil changes so easy, you can finally do oil changes without a garage or in the dead of winter! Save hundreds of dollars in labor for a simple task.
Oil changes demonstration with our Oil Drain Valve
[media]http://www.youtube.com/watch?v=gVmq8-obCEc[/media]
This video shows how easy it is to do an oil change after installing our Oil Drain Valve. Even my girlfriend Mina can do it with ease!
Installation
Please visit: http://installation.js2k.com for installation instructions.
Cost:
$33.99 for the Valve and required adapter
Purchasing:
Please head to JS2K.com! to make an order.
Here is a direct link to the valve for the S2000: Valve with Adapter (S2000, Prelude, '99+ 4cyl Acuras) Honda S2000 Oil Drain Valve [] - $33.99 : JS2K.com!
FAQ
Q. How much does the Engine Oil Drain Valve stick out from the oil pan?
A. S2000s equipped with the Oil Drain Valves need not worry about ground clearance, as the valve extends parallel to the ground. If your oil pan does not scrape, then valve will not. In fact, many points of the frame are lower than the oil pan or the valve.
Q: Do you have them for other applications?
A: I do have applications for all Hondas and any other vehicle. Please PM me for a quote.
Q: What Oil Pan was used?
A: Autozone carries an oil drain pan that will fit under S2000s lowered 2 inches as shown in the video.
It costs about $2: Link here. The drain pan measures 3.5" in height.
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
Old Aug 23, 2010 | 09:16 PM
gCHOW's Avatar
send payment via paypal?
Old Aug 23, 2010 | 09:33 PM
Kev!n's Avatar
ill send $ on the first. pay day
Old Aug 23, 2010 | 09:37 PM
JS2k.com's Avatar
Sponsor
Please. My email address is Joey@JS2k.com.
__________________
_________
Old Aug 23, 2010 | 09:38 PM
JS2k.com's Avatar
Sponsor
Thanks!
Okay, time for bed. Need to be awake enough for my real job tomorrow.
__________________
_________
Old Aug 24, 2010 | 12:21 AM
slowpokeS2K's Avatar
is there anyway you can setup a list to show how many people have paid already?
Old Aug 24, 2010 | 04:49 AM
DJ8684's Avatar
Just sent u payment!
Old Aug 24, 2010 | 05:44 AM
JS2k.com's Avatar
Sponsor
Thanks for your business!
__________________
_________
JS2k.com's Avatar
Sponsor
Thank you for your purchase!
__________________
_________
Old Aug 24, 2010 | 05:45 AM
JS2k.com's Avatar
Sponsor
Already did. But I moved it to the top of the 2nd post so it's easier to spot.
__________________
_________
