Open Header/Open Cat
Old Aug 28, 2010 | 08:11 PM
racecar fun's Avatar
Default Open Header/Open Cat
I recall someone saying that there were issues from running an open header/open cat?
I want to know, if it is bad to run your car like this, what happens and why does it happen.
TIA
Old Aug 28, 2010 | 08:16 PM
whiteflash's Avatar
1) Well unless you have EMS, you'll be throwing a code for your secondary O2 sensor for one
2) It's highly illegal
3) Noise
4) Smell
As far as performance goes; #1 is all you'd have to worry about
Old Aug 28, 2010 | 08:18 PM
*I didn't see your edit
I understand the smells,codes,legal issue
So there are no unsafe issues? I remember reading somewhere that it was unsafe or it would hurt performance.. guess I'm wrong.
Just tried to clear a thought.
Old Aug 28, 2010 | 08:46 PM
zeroptzero's Avatar
you will lose performance with a loss in torque, you need approximately 3 feet of exhaust pipe from the end of a header to maintain torque in the power band.
Old Aug 28, 2010 | 09:30 PM
^thanks & if you dont mine me asking, where was it found to be 3 ft?
Old Aug 28, 2010 | 09:45 PM
Seattle2k's Avatar
Uhm, car might run lean as well.
s2k dre's Avatar
Open Header with a test pipe would be good enough.
Old Aug 28, 2010 | 11:26 PM
H22toF20's Avatar
You have proof of this? Open header has been proven to make the most power time and time again. Check out the All Motor section on HT.
EDIT Actually on an S2k this might be different. All of the headers I've saw have a very short collector so it'll bolt to the OEM cat. If you do decide to run open header, you might think about bolting different length pipes to the header, to get the optimum collector length.
Old Aug 28, 2010 | 11:31 PM
realblag's Avatar
A header and short piece of exhaust (proper length and diameter on both) helps scavenge the exhaust from the cylinders therefor more air goes in on the intake stroke.
Old Aug 28, 2010 | 11:36 PM
H22toF20's Avatar
The scavenging takes place in the collector, which is part of the header itself. The collector is actually the most important part of the header; length, diameter, taper are all factors. Everything after that is useless as far as power is concerned.
