My Divided Manifold and Turbo Failure
Old Sep 1, 2010 | 08:20 PM
jaundice's Avatar
Default My Divided Manifold and Turbo Failure
Well, I have had my PFAB divided ELT Manifold and divided GT35R exhaust housing for several months now. I have the same setup as JoeyBalls, except that I have a built 9:1 compression motor and AP1 cams and head. I had difficulty making anywhere near the numbers that Joe made. I could only make 390 at 25 psi. I bought an Alaniz head and swapped that in. Numbers actually got worse. I took it to a different tuner (Tony at T1 in Dallas) and he told me that my issue was the 1.06 divided exhaust housing. It spooled very quickly (made 20 psi at 4000 rpm) but maxed out very quickly. I spent hours researching this kit, and talked with Pang and watched Joe's build, and just could not imagine that the housing was the issue. Well, he was right. He swapped in a non-divided 1.06 T4 housing on my divided manifold and instantly picked up 100 hp. Final tune on pump gas is now where it should be on a low compression motor. I made 491 hp and 340 torque at 19 psi (93 octane pump gas). I am finally happy with this purchase. Believe it or not, it actually still spooled very quickly with the divided manifold.
So, long story short, for whatever reason, my AP1 low compression motor needed more exhaust flow than the divided 1.06 housing would offer. I know that there are several AFI kits and CFT kits that are using divided mani's, and if you don't make the numbers you want, check out a bigger exhaust housing.
Here are the dyno graphs for comparison. The lower numbers are the divided housing and the bigger, better numbers are the non-divided housing (both are 1.06)
First dyno is WG only and second dyno is 60% duty cycle, which is 19 psi.
Old Sep 1, 2010 | 09:21 PM
m R g S r's Avatar
you should have never questioned tony, he's the man!
Glad your numbers are where they should be now
Old Sep 1, 2010 | 09:33 PM
jaundice's Avatar
I agree, Tony is the man. Should have taken it to him first...
Old Sep 2, 2010 | 03:21 AM
kutsujula's Avatar
Glad you got it figured out, was yours the yellow one?
Old Sep 2, 2010 | 03:33 AM
jaundice's Avatar
Yep. Been at Tony's place snuggled next to yours for nearly a month...
Old Sep 2, 2010 | 03:41 AM
JoeyBalls's Avatar
nice numbers glad u got it figured out
Old Sep 2, 2010 | 04:17 AM
kutsujula's Avatar
Haha. Well good to see you got it running to
It's full potential!! I'm heading down there tomorrow.
Old Sep 2, 2010 | 04:48 AM
spectacle's Avatar
Interesting. Non divided made more power than divided with the same spool characteristics. I anticipate some minds being blown on this one.
PS - thanks for not calling it twin scroll
Old Sep 2, 2010 | 05:22 AM
camuman's Avatar
this is what everyone has been saying lately though, if you go divided housing, go big.
at least you showed everyone 100% thats true.
Old Sep 2, 2010 | 05:47 AM
HMFIC's Avatar
Very cool..
def need to get rebuilt on lower compression so i raise boost safely.
