17x9.5 +38 w/ 255/40/17 X4
Ok I KNOW its been discussed and I apologize just want some things clarified...
just ordered enkei rpf1s in 17x9.5 +38 with 255/40s all around I know I need to:
1. Roll Front and rear
2. Relocated rear bumper tabs
3. Trim Rear Bumper
4. - Camber
But I have some extra questions.. with -2.5 (as much negative as i wanna run) will i need to also PULL the fenders?? and if so how is this done?? just keep going with the roller and heatgun? also the fender liner needs to be retained.. do i just bend the tabs up witht he rolled fender and reinstall it??
help would be appreciated wheels arrive tuesday got the roller rented for wednesday!!
3. Trim Rear Bumper
4. - Camber
-2 degrees & smaller tires will work. No matter what you'll have to have some kind of neg camber & a roll. You don't really need a pull. ITs almost garbage to pull the S2 fenders because of the homo rear bumper.
It is going to be trial and error. Every tire is slightly different width and height. The most negative camber the the better. The 9.5 wheel and that low of an offset is going to take some time.
You're going to need to pull the rears and the fronts, no doubt about it. Unless you're going to run stupid amounts of camber to make them fit.
I ran RPF1's with 17x9 +45 F and 9.5 +38 R and it was a pain in the ass to make fit.
Yea the tires arrived today.. look giant lmao.. Falken Azenis RT615ks 255/40/17.. Im only going to run -2.5 camber (atleast thats all I want to run) so I figure I set the camber then roll and trial till they fit.. rims arrive tuesday mounted wednesday and fender work starts thursday.. im just scared of denting the fenders!! guess ill just have to be very careful with the heat gun!
