Valve adjustment question
Old Sep 17, 2002 | 06:21 AM
Squeezer's Avatar
Default Valve adjustment question
Question for the experts out there. When doing the valve adjustment, the service manual says to turn the crankshaft 180". I can eyeball how much I turn the wrench and look at the valves to see how much they are open and get an approximate 180 degree turn, but is there a proper method for knowing when you have turned the crank 180 degrees?
Old Sep 17, 2002 | 06:30 AM
Gernby's Avatar
There are engraved marks (mine are also painted) on the cam gears that will line up in various ways with each other and / or the lip of the head. The book has diagrams showing how these marks will line up for each cylinder.
Old Sep 19, 2002 | 07:39 AM
marcucci's Avatar
Another way to tell is that you want the cam lobe pointed away from the rocker arm on which it wipes. The Honda method doesn't really do this (not 180 degrees), but is close enough. Make sure that the cam lobe is pointing away from the rocker, that's where you want to do the adjustment.
Rockin S2K
May 4, 2018 05:15 AM
Shordmcman
May 20, 2012 07:23 PM
trich101
Apr 15, 2011 09:54 PM
03BlkS2k
Mar 22, 2009 04:53 PM
apex2k
May 25, 2004 07:48 AM
