Mark this thread as Sold
FS: Complete Inline Pro street kit with extras!
This is EVERYTHING you are going to need in order to install the kit and hit street!!!!!
Inline Pro Street Kit not “Tuner” Kit
Here are a few pictures..
These are the costs of parts:
Turbo kit: 4000
Ball bearing upgrade 500 (I bought this separate from the kit and paid 1300)
Coating on manifold: 200
Turbo manifold match ported: 100
Downpipe: 1200
AEM 1052U: 1200
Fuel pump: 100
Injectors: 475
Turbo blanket kit: 150
Oil pan/tapped for return: 150
AEM boost solenoid, 3.5 bar map sensor, oil press sensor and custom harness: 225
Vacuum lines, upgraded T-bolts, ARP studs for top exhaust bolts, custom overflow bracket etc: 150
Base map: (I paid 450 for my tune and put many hours into further tuning it after)
Total I spent: 9700
• Inline Pro Cast Bottom Mount Manifold
o HPC Coated
o Gasket matched & port casting cleaned Up
o ARP Exhaust manifold studs (3) for top studs
• Intercooler Piping
o Polished
o Premium Stainless T-Bolt Clamps
• Precision Ball Bearing 5965 w/ B cover
o About 3000 miles of service
o Water Cooler Center Section
o Oil Drain Line
o Turbo Oil Drain Adapter
o Oil Pan Pretapped
o Turbo Oil Supply Line, Fittings & restrictor
• 38MM Turbosmart Ultragate - Wastegate
o Stainless Steel dump tube
• 3” Custom Made Tig Welded Stainless Downpipe (1250 dollar item)
o 3” Sound Performance Boost Actuated Cutout
o 4” Stainless Flex Joint
o Bolts Up To Factory 3” House Flange to meet up to factory exhaust
o Secondary 02 Bung
• Precision 600HP Intercooler w/ Custom Brackets
• Inline Pro Oil Filter Relocation Kit
• AEM oil pressure sensor
• AEM boost solenoid
• Custom harness for boost solenoid and oil sensor (plug and play)
• AEM Dry Flow Filter
• Custom Turbo to Filter Standoff
• Inline Pro Blow Off Valve
• DEI Turbo Blanket
• Custom coolant Reservoir Bracket
• Inline Pro Instructions
• All Required Hardware to Install
• Vacuum Hoses
• ISP Secondary Air Injection Block Off Plate
• NGK BKR8EIX Spark Plugs
• *NIB* Walbro 255LPH Fuel Pump
• AEM EMS 1052U
o Wideband O2 sensor with heat cover
o AEM 3.5 Bar Map Sensor & Pigtail
o AEM Boost Solenoid & Fittings
o High speed RS232 to USB cable with software
• ID 1000cc Injectors
o PNP Injector Pigtails
o Spacers & Extra O-rings
Free Base Tune
Asking Price Shipped in the US $5,000
Located in 91766 California
My name is Kevin and you can contact me via PM.
Thanks guys.
Turbo kit: 4000
Downpipe: 1200
AEM 1052U: 1200
Fuel pump: 100
Injectors: 475
Total I spent: 9700
o HPC Coated
o Polished
o Oil Drain Line
o Oil Pan Pretapped
o Secondary 02 Bung
• DEI Turbo Blanket
• Vacuum Hoses
• AEM EMS 1052U
Free Base Tune
Thanks guys.
