what ECU i have?
My S is Euro "AP2".
of course it's still called AP1 but has F20C2 motor with DBW.
According to Hondata web site Flashpro part# FP-S2K-INT can be used
for "2006 + Europe S2000" with ECU part numbers PCX-G01 through PCX-G16.
So today i decided to remove the kickpannel (it's on the left side) to check y ECU part# - and what do i see?
no markings whatsoever
what do i do?
what do i do?
Originally Posted by Croc,Dec 7 2010, 06:19 PM
My S is Euro "AP2".
what do i do?
what do i do?
If it is a late registered 2006 car then your ECU should be a G12 or G13
If it is a 2007, then your ECU should be a G13 or G14
Or, if it is an early registered 2008 car your ECU should be a G15 or G16
If you do not want to take the ECU out, PM me your VIN number and I will tell you which one it is.
HTH
Chris.
Interesting Chris, I recall a post earlier in the year from an owner that had a car with an ECU outside of the Hondata given range, I didn't realise that these numbers were by date/age, do you know if there are other changes such as firmware revsions?
I know of two GT100 that have had Flash Pro's installed but assume being 2009 cars they are beyond G16.
It doesn't really matter. If you have an '07 model year than the Hondata for DBW systems should work. I don't want to say will because you never now what some monkey may have done at some point in the past. (I'm not suggesting you are a monkey)
before i pay 700$ i'm just tring to make sure Flashpro will work
do you mean the upper edge?
if YES - i have dentist's mirror which i can try to use to see this whithout unbolting the ECU.
Originally Posted by phils2k,Dec 7 2010, 08:20 PM
if you unbolt the ecu its on the opposite edge which i cannot see
It'll work. If it makes you feel better, tell the vendor what car you have. If you are buying from the UK you are protected by distance selling regulations anyway.
What are you trying to accomplish, by the way? What mods do you already have, or plan? If the car is mostly stock you will not see any real gains and are better spent using the money for something else.
