Eternallx's Turbo Build
Old Jan 7, 2011 | 06:10 PM
EternalLx's Avatar
Default Eternallx's Turbo Build
Well PTuning kits started shipping and I just got mine so I thought I would start the build thread now. The turbo virus is really contiguous here in the Metro area
I had a KW supercharger @ 12psi before this but pushing my luck the rotrex took a dump @ 14psi Well onto the build with pics!
-PTuning Turbo kit
-GTX3076R
-Recirc dump
-PTuning 3" Dual Exhaust
-Individual/Direct Port WMI
-SOS Throttle Body
-Vented valve cover
-Krankvent
-PWR 55mm Radiator w/ Intank Oil Cooler
-PTuning Air to Oil Cooler kit
-SOS Twin Carbon Clutch
-ID1600
-Full Blown 340 pump
-Inlinepro return fuel kit
-PLX gauge--A/F-Ect-OilT-OilP
Direct meth injection setup Meth related Parts list w/ links on page 3
From the top clock wise:
Cooling Mist controller/flow/boost gauge
Flow sensor w/ check valve and filter
Nozzles with CM5 injectors
Direct port manifold
Aquatec/AEM 200psi pump and bottle
Zip tie for now.. might make a bracket later on
Check valve and flow sensor on top of clutch master cylinder
Meth tank and pump in trunk
Old Jan 7, 2011 | 06:11 PM
EternalLx's Avatar
Current state of engine bay... boring...
GTX
GTX eating my cat
Installing what we can this Sunday with S2000 Turbo Surgeon Minitoyota
Stay tuned for updates of install
Current tune date with Evans is Feb. 2nd but i'll shoot for late this month if theres space
Old Jan 7, 2011 | 06:15 PM
Jacko's Avatar
I have been waiting for this one
Old Jan 7, 2011 | 06:20 PM
EternalLx's Avatar
And we're still waiting on you Good thing its gonna be SICK
Old Jan 7, 2011 | 07:10 PM
donaldmejr's Avatar
[QUOTE=Evans Tuning,Jan 7 2011, 07:31 PM] Heads up on that meth kit, I had issues with a turbo RSX using something similar.
kels_2k's Avatar
metro is turbo heaven and a way of Life !!
I am going to start my build thread soon
what EMS do you have david ?
Old Jan 7, 2011 | 07:23 PM
EternalLx's Avatar
Originally Posted by Evans Tuning,Jan 7 2011, 10:31 PM
Heads up on that meth kit, I had issues with a turbo RSX using something similar. The car would go super rich after a pull, in the 9~10:1 range and make the car bog down until the a/f gradually leaned out. After some trial and error we figured out that the meth mixture would leak into the engine after the check valve was closed. The vacuum in the plenum/runners would pull the mixture in. I never figured out a way to make it work right. He wasnt using the same brand kit though.
Interesting........ I'll try to do some kinda test asap.
Thanks for the heads up
Same thing has to me with my cooling mist trunk mount kit on my JRSC B20. But my check vavle is located on the tank. Hopefully you have better luck with the setup.
I hope so!
[QUOTE]metro is turbo heaven and a way of Life !!
Old Jan 7, 2011 | 07:29 PM
donaldmejr's Avatar
I was told to try and add a check valve right at the nozzle...but I'm only using one and not 4
Old Jan 7, 2011 | 08:19 PM
metros's Avatar
Looking forward to seeing what numbers you put down with water/meth injection. You're going to be extremely happy with the final kit that PTuning has put together.
Old Jan 7, 2011 | 11:17 PM
S2000_FUN's Avatar
Keep us posted. I really want to see the number you will put down. Nice build
