maintenance light (not how to reset)
Old Nov 7, 2002 | 03:52 PM
rocketman's Avatar
Default maintenance light (not how to reset)
anybody know if the maintenance light comes on and stays on at a certain mileage after the maintenance point (if the light is not reset)?
Had my 22,500 maintenance done and I noticed the light still came on when I started the car - dealer didn't reset it. I haven't gotten around to doing it myself and mileage is a little past 23K and the light came on while I was driving tonight.
I guess I'll find out if it's a problem or not when I reset it, but it would be nice to know if what happened is normal or not.
Old Nov 7, 2002 | 06:00 PM
Stratocaster's Avatar
Deleted because I can't read
Old Nov 7, 2002 | 06:03 PM
airgate's Avatar
Stratocaster, rocketman knows how to reset his light.
Old Nov 7, 2002 | 06:08 PM
yellow2001's Avatar
yes, it does come on at certain miles. I don't remember at what mileage, but my just came on at 31000 miles.
Old Nov 7, 2002 | 06:20 PM
Ok, I will shut up now <sitting in the corner, with dunce cap on>
It come on at the standard maintenance interval (7K). I don't know if is the next time is 14k or 7k from the reset. Anyone know?
Old Nov 7, 2002 | 06:38 PM
boiler's Avatar
My standard maintenance interval for the light to come on was 5160 miles. I do believe that it comes on when you turn the ignition key on and stays briefly for a while, then stays on solid after that, if not reset.
Just reset it, it only takes a second.
Old Nov 8, 2002 | 07:33 PM
bchaffin's Avatar
How do you reset the light?
Old Nov 9, 2002 | 03:55 AM
djohnston's Avatar
https://www.s2ki.com/article/articleview/4/1/8/
Old Nov 9, 2002 | 05:32 AM
boiler's Avatar
The link doesn't work for some reason.
However, to reset the maintenance light, hold the odometer reset button down, then turn the ignition key to the "on" position until the light stops flashing. You must continue to hold the reset button until the light stops flashing.
I know, I know, that's NOT what the "procedure" tells you to do, but it works on both of my hondas (my S2000 and my wife's Odyssey).
Bob
Old Jun 30, 2006 | 03:50 PM
Yogi'sS2K's Avatar
Bob
What does the "procedure" tells us to do?
