Do i need to wire up the power antenna wire for aftermarket HU?
Old Dec 25, 2002 | 03:39 PM
stockae92's Avatar
Default Do i need to wire up the power antenna wire for aftermarket HU?
I am wondering do i have to wire up the power antenna wire (blue wire) of the HU harness?
i am installing a alpine HU. after i plug the antenna wire into the HU, i seems to have no problem with FM reception. i don't know about AM yet though.
Old Dec 25, 2002 | 08:25 PM
SC_Highlander's Avatar
Yes. Our antenna has an amplifier that is powered by the 'power antenna' lead on the wiring harness.
Old Dec 26, 2002 | 05:18 AM
PilotChris's Avatar
Wow, amazing.. I was just going to ask that exact same question.
Thanks guys
Old Dec 26, 2002 | 09:34 AM
stockae92's Avatar
the dumb thing is i am using scosche HA08 harness for '98+ Honda.
and they doesn't have a wire for power antenna ...
they have wire for illumination/dimmer though (which i can't use)
Old Dec 26, 2002 | 10:53 PM
stockae92's Avatar
without wiring the power antenna lead
i seems to have little or no problem recieving FM radio station
but AM radio station reception is very bad.
somebody has the same experience?
Old Dec 27, 2002 | 05:08 PM
Stratocaster's Avatar
Yes, I have this problem, but I get no AM at all. I have a new harness waiting for me to install and fix it. I am just too busy building my sub enclosure to get this now. Maybe soon.
Old Dec 30, 2002 | 07:46 AM
jeffbrig's Avatar
Yes, I saw the exact same thing. The radio pulled in every local FM station I listen to with no problem, but AM couldn't find a single station. I removed the radio and connected the power antenna lead, and everything is there now. Also noticed that the FM signal is cleaner and louder as a result, as you'd expect with an XX dB boost on a powered antenna.
Jeff
Old Dec 30, 2002 | 09:52 AM
stockae92's Avatar
here comes my other question
how can i add a pin/wire to my aftermarket harness?
i am using Scosche harness for +99 Honda and they don't have a power antenna wire.
Old Dec 30, 2002 | 10:09 AM
If there are any unused wires on your existing harness, you could pull the wire (and the pin) out of the harness, then move it to the pin location you need. I've done this a couple of times in the past. You just need to make sure you re-seat the pin properly so it won't push out when you connect the harness to the stock plug.
Old Dec 30, 2002 | 10:54 AM
stockae92's Avatar
i can just pull it out without breaking it?
there are some illumination/dimmer pin/wire that are unuse which will be great for this
