IntroductionsMake your introductions to the S2000 owner community. Discussions and comments from new and future S2000 owners. You will get a warm welcome, friendly and helpful advice. The 'Start Button' of the forums.
NOTE: I am building this list to highlight the changes between 2004-5 and 2006-7 S2000s as we don't have a single thread that highlights the details in one place. Feel free to add/correct so we can get a definitive thread up!
This is a continuation of the other yearly changes threads.
The biggest news for 2006 includes drive by wire, vehicle stability assist, and a new color - Laguna Blue Pearl.
MSRPs
S2000 - $34,050
For the 2006 model year, all Honda horsepower and torque specifications have been updated to reflect revised Society of Automotive Engineers (SAE) J1349 (Rev 8/04) net calculations that went into affect in January of 2005. HP is now rated at 237 horsepower at 7,800 rpm and 162 lb-ft. of torque at 6,800 rpm.
Drivetrain & Exhaust:
- Drive by wire throttle control system (works with the VSA)
- Vehicle stability assist
- Brake Assist - Braking pressure is maintained momentarily after the driver's initial braking action to help the driver stop promptly. It deactivates when the driver releases pressure on the brake pedal
Interior:
- Revised seat design - seats no longer have back pockets. headrests are closed, shape ane leather materials are different
- Standard headrest speakers
- Small map shelf added under passenger side dash
- IP now has an outside temperature gauge
- Center console cover is now black, VSA button located where hazard lights used to be
- SRS passenger airbag is now switched on and off based on passenger weight
- The previous Maintenance Req'd light has been replaced with a new system. Oil life is calculated based on RPM's and operation conditions to determine oil change intervals
Exterior:
- Daytime running lights now standard
Colors:
Laguna blue over black - new color in 2006
Berlina Black over black
New Formula Red over black
Sebring Silver Metallic over black OR red over black
Silverstone Silver Metallic over black OR red over black
Grand Prix White over black
Suzuka Blue Metallic over black
Rio Yellow Pearl over black
Other Stuff:
- Weight increases from 2835 to 2855 lbs
- Maintenance minder system
- Power train warranty extended to 5 years/60,000 miles
- CARB emissions rating is now LEV-2
- Revised HID has new "soft" fresnel lens, so light cut-off is not as sharp
In 2006 Honda released the S2000 RJ special edition
- F-1 inspired, called the Honda S2000 RJ
- No changes to the performance of the car, just a visual changes
- Pearl White Premium exterior and a red and balck interior
- Has the signatures of Honda’s F-1 drivers Rubens Barrichello and Jenson Button
- Only 50 produced and sold only in Italy, France and Spain
ENGINEERING FEATURES 2006 Honda S2000
2.2 Liter, 237-hp, 16-Valve DOHC VTEC Engine x
Drive-By-Wire Throttle x
Vehicle Stability Assist (VSA) x
Torque-Sensing Limited-Slip Differential x
Aluminum-Alloy Cylinder Head and Block w/ Fiber-Reinforced (FRM) Cylinder Walls x
Multi-Point Programmed Fuel Injection (PGM-FI) x
Forged Aluminum Pistons x
Electronic Ignition x
6-Speed Manual Transmission x
Electric Power Rack-and-Pinion Steering x
Power-Assisted 4-Wheel Disc Brakes w/ ABS x
Low Back-Pressure Exhaust System x
Low-Emission Vehicle (LEV-2) Rating x
EXTERIOR FEATURES 2006 Honda S2000
Electrically Powered Soft Top x
High-Intensity Discharge (HID) Headlights x
Daytime Running Lights x
Lightweight Aluminum Alloy Wheels x
Dual-Outlet Exhaust with Chrome Exhaust Tips x
Impact-Absorbing Body-Colored Bumpers x
Dual Power Side Mirrors x
Rear Glass Window w/Defroster x
Body-Colored Hardtop x
Trunk Spoiler x
INTERIOR FEATURES 2006 Honda S2000
Dual Airbags (SRS) x
Air Conditioning with Micron Air-Filtration System x
AM / FM Stereo with CD Player x
XM Satellite Radio x
Headrest Speakers x
Power Windows x
Cruise Control x
Digital Instrument Panel x
Outside Temperature Gauge x
Maintenance Minder System x
Leather-Wrapped Steering Wheel x
Leather-Trimmed Seats x
Center Console Storage Compartments w/ Lock x
Beverage Holders (2) x
3-Point Seat Belts with Pretensioners x
Remote-Operated Audio Controls x
Engine Start Button x
12-Volt Power Outlet x
Immobilizer Theft-Deterrent System x
Keyless Entry System with Remote Trunk Release x
Aluminum Shift Knob with Leather x
Aluminum Pedals x
Aluminum Foot Rest x
EXTERIOR COLORS / INTERIOR COLORS 2006 Honda S2000
Laguna Blue Pearl/Black x
Suzuka Blue Metallic/Blue x
Grand Prix White/Tan x
New Formula Red/Black x
Sebring Silver Metallic/Black or Red and Black x
Silverstone Metallic/Black or Red and Black x
Berlina Black/Black x
Rio Yellow Pearl/Black x
I would ask the UK & Spain forum folks about this, as these threads are pretty North America-centric, but I do believe the 2006+ S200s have an auto cutoff for passenger airbags based on weight. If not, there are people here who have had them installed in their S2000s.
