S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   Introductions (https://www.s2ki.com/forums/introductions-21/)
-   -   Changes between 2006-7 & 2008, & the CR (https://www.s2ki.com/forums/introductions-21/changes-between-2006-7-2008-cr-525439/)
Saki GT Sep 13, 2007 02:40 PM
NOTE: I am building this list to highlight the changes between 2006-7 and 2008 S2000s as we don't have a single thread that highlights the details in one place. Feel free to add/correct so we can get a definitive thread up!
This is a continuation of the other yearly changes threads.
Changes from MY00, 01, 02, 03 - https://www.s2ki.com/forums/index.php?showtopic=599836
Changes from MY03 to 04-05 - https://www.s2ki.com/forums/index.php?showtopic=483593
Changes from MY04-05 to 06-07 - https://www.s2ki.com/forums/index.php?showtopic=538016
The biggest news for 2008 is the introduction of the Club Racer (CR) trim level S2000. In this thread are detailed listings of both the changes from the 2007 to 2008 model year for the normal S2000 and the details on the CR trim.
Honda made no changes to the S2000 between 2008 and 2009, and announced the end of S2000 production will be 2009.
MSRPs
2008 prices:
http://www.hondanews.com/categories/898/releases/4277
S2000 - $34,300
S2000 CR (air conditioning and audio system deleted) - $36,300
S2000 CR (air conditioning and audio system included) - $37,300
2009 prices:
http://www.hondanews.com/categories/898/releases/4711
S2000 - $34,795
S2000 CR (air conditioning and audio system deleted) - $36,795
S2000 CR (air conditioning and audio system included) - $37,795
The 2008 S2000:
Engine:
- No changes
Drivetrain & Exhaust:
- No changes
Suspension & chassis:
- revised spring and damper tuning "that subtly influences steering feel and high speed vehicle behavior".
- Coil springs - Front: Stiffer by 7%, Rear: Stiffer by 9% (from 2007 spec)
- Dampers - Front: Damping Force Increased 10%, Rear: Damping Force Increased 5% (from 2007 spec)
- Satbilizer bars - Front from 26.5 x t4.5 (2007) to 27.2 x t5.3. Rear has no change
Wheels & Tires:
- 17-inch aluminum alloy, twin 5-spoke pattern wheels painted silver
Interior:
- Revised instrument panel meters - Specifically, the fuel and temperature meters now reside along the arc formed by the tachometer instead of a semi-circle configuration below and to the right of the tachometer.
- Minor revisions to the seat design
Exterior:
- No more windshield tape - windshield frame now matches the rest of the body
Colors:
Berlina Black over black
https://cimg8.ibsrv.net/gimg/www.s2k...9ce97d19d3.jpg
Berlina Black over red & black
https://cimg9.ibsrv.net/gimg/www.s2k...ac28dd399c.jpg
Laguna blue over black
https://cimg2.ibsrv.net/gimg/www.s2k...28f4fe3c9a.jpg
New Formula Red over black
https://cimg3.ibsrv.net/gimg/www.s2k...c0eb179ca1.jpg
Chicane Silver Metallic over black (Chicane is similar to Silverstone from previous years, but darker)
https://cimg4.ibsrv.net/gimg/www.s2k...f3c08c7d32.jpg
Chicane Silver Metallic over black and red
https://cimg5.ibsrv.net/gimg/www.s2k...4d125fcb13.jpg
Grand Prix White over red and black
https://cimg6.ibsrv.net/gimg/www.s2k...62aefe0b54.jpg
Rio Yellow Pearl over black
https://cimg8.ibsrv.net/gimg/www.s2k...3067ba182e.jpg
Other Stuff:
- Weight increases from 2855 to 2864 lbs
- Tire Pressure Monitoring System (TPMS)
No changes from 2008 to 2009 other than color - Chicane is replaced with Silverstone.
Honda Press Releases: (Most cover both the standard and CR S2000)
08.15.07 2008 Honda S2000 - Introduction - http://corporate.honda.com/press/article.aspx?id=4099
08.15.07 2008 Honda S2000 -- Body - http://corporate.honda.com/press/article.aspx?id=4098
08.15.07 2008 Honda S2000 -- Chassis - http://corporate.honda.com/press/article.aspx?id=4097
08.15.07 2008 Honda S2000 - Powertrain - http://corporate.honda.com/press/article.aspx?id=4096
08.15.07 2008 Honda S2000 -- Interior - http://corporate.honda.com/press/article.aspx?id=4095
08.15.07 2008 Honda S2000 Specifications and Features - http://corporate.honda.com/press/article.aspx?id=4094
09.13.07 2008 Honda S2000 Elevates Sports Car Formula with Tightly-focused CR 'Club Racer' Edition
Track-oriented S2000 CR expands lineup; minor updates enhance all models - http://corporate.honda.com/press/article.aspx?id=4247
Standard Reviews:
NetCarShow.com - http://www.netcarshow.com/honda/2008-s2000/
CR Reviews:
Edmunds - http://www.edmunds.com/apps/vdpcontainers/...02/pageNumber=1
Road & Track vs a Nismo 350Z - http://www.roadandtrack.com/article.asp?se...article_id=6057
The S2ki CR official thread - https://www.s2ki.com/forums/index.ph...ic=517701&st=0
Honda Press images for 2008 - https://www.s2ki.com/forums/index.php?act=m...bum&album=25680
2008 profile shot - the biggest visible change are the new wheels. Also note the new seats, which are taller and now rise above the roll hoops. This silver is also new for 2008 - Chicane Silver Metallic.
https://www.s2ki.com/forums/index.ph...mg=466986&md=1
https://www.s2ki.com/forums/index.ph...mg=466989&md=1
The Imola orange is a 2007 model, for reference.
https://www.s2ki.com/forums/index.ph...mg=425958&md=1
Other than the instrument panel and seat design, the interior is the same.
https://www.s2ki.com/forums/index.ph...mg=466992&md=1
https://cimg6.ibsrv.net/gimg/www.s2k...3c0dafccc8.jpg
The CR has a much more extensive list of changes. One of the biggest changes is the removal of the folding soft top, now replaced with a removable hard top.
Engine:
- No changes
- Quicker steering ratio of 13.8:1 (compared to 14.9:1) Steering goes from 2.6 to 2.4 lock to lock
- Added steering gear box stiffeners
- Sport muffler - tuned for sound
- 1.8-inch vented front brake discs and 11.1-inch solid rear brake discs
- Coil springs - Fronts stiffer by 37%, rears stiffer by 17% than normal 2008 S2k
- Mono-tube, gas-pressurized dampers - Frot increased 50%, rear increased 32% more than normal 2008 S2k
- Rear body brace where soft top used to fold
Wheels & Tires:
- 17-inch aluminum alloy, twin 5-spoke pattern wheels painted "Kaiser Silver" - darker than regular S2000 wheels
- Rear tires are 255 width
- Ultra-high performance Bridgestone RE070 tires, 215/45R17 front and 255/40R17 rear
Interior:
- Cloth high-grip fabric seating surfaces with synthetic suede trim
- Seat foam conforms more to the occupant for an enhanced fit
- Instrument panel includes a "peak-power indicator." When the engine is operating at peak power, a round, green light illuminates to the right of the digital speedometer
- Spherical aluminum shift knob rests 12.6 mm lower for a 6 percent reduction in shift stroke compared to the regular S2000 knob
- Shift load effort increased by 10 percent for even more direct feedback when engaging a gear
- Floor mats have a yellow S2000 logo
- Carbon-fiber look interior trim pieces, including radio door and center console
Exterior:
- Aerodynamic body kit for reduced coefficient of lift (Cl) by 70-80% and improved balance
- Kit includes an underbody front spoiler and a rear wing
- Removable black aluminum hardtop
- The contour of the roof is designed to influence aerodynamics at the rear of the vehicle
- Cowlings sit behind the roll bars and were aerodynamically designed to work with the rear wing
Colors:
- Apex Blue Pearl (the only CR exclusive paint color)
https://cimg1.ibsrv.net/gimg/www.s2k...ac9c00f54e.jpg
- Berlina Black
https://cimg0.ibsrv.net/gimg/www.s2k...d69e7f90b9.jpg
- Grand Prix White
https://cimg7.ibsrv.net/gimg/www.s2k...e60f2e47c2.jpg
- Rio Yellow
https://cimg9.ibsrv.net/gimg/www.s2k...9ec05abb1a.jpg
- All CRs have the same black and yellow interior
Other Stuff:
- Weight 2813 lbs (2765 without hardtop) (+42 with audio and AC)
- There is no soft top
- Radio and air conditioning are factory options
- There is no spare tire or jack, instead there is a tire sealant repair kit
- No sound insulation materials in the floor, tunnel, hood and trunk
CR profile shot - biggest visible changes include the aero pieces, including the front lip and rear wing. Also note the black badges and exhaust tips, plus 5-spoke wheels.
https://www.s2ki.com/forums/index.ph...mg=466997&md=1
The rear wing.
https://www.s2ki.com/forums/index.ph...mg=467000&md=1
Black aluminum hard top.
https://www.s2ki.com/forums/index.ph...mg=466999&md=1
The CR interior has different stitching in the panels, shifter boot and seats, and CR seats have a distinctive gold weave. The radio door and center consle also have a carbon pattern weave look. Also, note the revised instrument panel and shift knob.
https://www.s2ki.com/forums/index.ph...mg=467001&md=1
The CR crossbrace - it mounts in tree places per side and replaces the soft top and motor.
http://i6.photobucket.com/albums/y24...o/HPIM0037.jpg
The CR in black
https://www.s2ki.com/forums/index.ph...age&img=451000
The CR in Rio
https://www.s2ki.com/forums/index.ph...age&img=450999
Saki GT Sep 13, 2007 03:06 PM
S2000 2008 Color Chart
https://www.s2ki.com/forums/index.ph...age&img=450470
Some vids:
http://www.youtube.com/watch?v=qx-aiCemZLU
http://www.youtube.com/watch?v=DvGa-NyJiKE
Saki GT Sep 13, 2007 07:49 PM
In 2009, Honda released a special edition in Europe:
- Grand Prix White
- Red interior
- Graphite wheels
- Red shift-boot stitching
- Same shift knob as CR, but with red lettering
- Black badging
PRESS RELEASE
Honda has announced that the Honda S2000 Ultimate Edition will go on sale from March 2009 in Europe. This limited edition has been produced to mark the end of production for the award winning sports car.
The Ultimate Edition retains its highly acclaimed 2.0 litre 9000 rpm VTEC engine and combines it with a Grand Prix White body and graphite coloured alloy wheels. The shade of the paint evokes the colour first used on Honda's 1964 F1 car and many sporting models since. The exterior colour combination with the dark metal alloy wheels and unique black S2000 badging gives a fresh look to the timeless shape of the roadster body.
The white exterior will be matched with a red leather interior and complimented by unique red colouring for stitching on the gear lever gaiter. Ultimate Editions will be marked out by their unique numbered plaques on the kickplates, denoting their position in the series.
The 2-seater sports car may now be almost 10-years old, but its 240PS 2-litre is still one of the highest output per litre and highest revving engines ever made. In recognition of its incredible power output, the Honda S2000's engine has won the International Engine of the Year category for 1.8 to 2.2 litre engines five times in its lifetime.
As the name suggests, the Honda S2000 Ultimate Edition will be the last version before global production of the model ceases altogether at the end of June 2009. Since the introduction of the Honda S2000 in 1999 until the end of 2008, Honda has sold 110,673 units worldwide - 19,987 of those in Europe.
The first viewing of the Ultimate Edition will be the 2009 Geneva International Motor Show starting with the press day on the 3rd March.
Gallery - https://www.s2ki.com/s2000/gallery/a...2009-ultimate/
https://www.s2ki.com/s2000/uploads/g...002_479658.jpg
https://www.s2ki.com/s2000/uploads/g...002_392948.jpg
https://www.s2ki.com/s2000/uploads/g...002_548929.jpg
Honda S2000 Edition 100 (2009) CAR review
By Mark Walton
First Drives
30 March 2009 12:00
To mark the end of its S2000 roadster after a decade of production, Honda UK is selling just 100 examples of this special run-out model, all in Grand Prix White with special graphite alloys, a red leather interior, and a serial number on the kick plate. But ten years on, can the S2000 still cut the mustard?
Has it really been ten years since the Honda S2000 was launched?
Yes, it has – the S2000 was launched back in 1999 as Honda’s ‘50th birthday present to itself’. Now, on its 60th birthday, it’s stopping production. So much for sentimentality.
Is it mechanically unchanged?
The S2000 has remained remarkably unchanged over the last decade, and the Edition 100 is no different. But don’t worry – that’s not through laziness on Honda’s part, it’s just that the spec of this car was pretty much perfect from the start.
So, ten years on, it has the same high-revving four-cylinder 2.0i VTEC engine that produces 237bhp at 8300rpm, and redlines at a headline-grabbing 9000rpm; the engine is mounted behind the front axle for a perfect 50:50 weight distribution and front-mid-engined agility; and it drives the rear wheels via one of the sweetest 6-speed manual gearboxes you can buy, and a Torsen limited slip diff. It also has electrically assisted rack-and-pinion steering, and double wishbone suspension all round. See? Pretty hard to improve, right?
And what’s it like to drive?
Despite being a decade old, the S2000 is such a pure-bred design, it remains the genuine article it always was. The interior is snug, the sports seats are supportive, the steering wheel chunky and purposeful. Press the start button (a real novelty back in 1999), dip the light clutch, and snick the tiny metal gear lever into first.
Once on the move, the engine (winner of International Engine of the Year five times over) proves to be friendly and tractable… yet strangely lacklustre at low revs. It’s incredibly easy to live with, trickling through town, but it’s so smooth and efficient it’s almost characterless, as though you’re driving a Civic.
It’s only when you get out onto an open stretch of road that you find out what all the fuss is about: press that throttle deep, and the revs rise, and rise... and rise some more… until you reach 5850rpm, and the VTEC cams engage. Suddenly all hell breaks loose – and now it feels like someone’s pressed the fast forward button, yet STILL the revs keep rising to an incredible 9000rpm. By the time you change, that engine is screaming like a motorbike, which certainly makes the hair stand up on the back of your neck. It’s just a shame the excitement sits so far up the rev range it’s hard to reach – you have to plan it, think ahead, schedule it in, to make sure you have the room you need to reach the giddy heights of the VTEC zone.
Do you always have to rev it?
No, not all the fun is hard to access – there’s a delicacy to the S2000 that’s always rewarding, no matter how fast you’re going. The steering is light and accurate, the responses sharp. It’s not a car for rally drivers, and tail-sliding is virtually impossible – it’s a circuit racer, and on the road it’s a car that feels neat, precise and predictable.
So how much is it?
There were still standard S2000s on sale in the UK as we closed for press, being heavily discounted down from the on-the-road price of £28,130 for the ‘Roadster’ (the standard car with an electric soft top), and £28,670 for the GT (a Roadster that also comes with a removable aluminium hardtop). Which means you’re looking at paying a premium to get this limited edition white car – it comes as a GT only, and costs £29,086. Just remember, the S2000 has aged incredibly well, it will probably always look this good, and it’s a dead cert to be a classic; I’m not saying buy one as an investment, but you could certainly buy one, knowing you’d still have a peach in 30 years’ time.
TRDLiquidSilver Sep 15, 2007 07:58 AM
anyone know how the so called "sport exhaust" on the CR compares to the stock exhaust?
Mystiqueskillz Sep 15, 2007 11:49 AM
So tell me why I didn't wait and got the 2008 model instead of the 2007. But at least I got the 2007 for a good deal back in June.
© 2026 MH Sub I, LLC dba Internet Brands
