S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   Introductions (https://www.s2ki.com/forums/introductions-21/)
-   -   HONDA KEY (https://www.s2ki.com/forums/introductions-21/honda-key-626684/)
youngkilla Aug 28, 2008 06:26 AM
HONDA KEY
IS IT TRUE THAT INSIDE THE HONDA S2000 KEY THERE IS A SPECIAL CHIP AND THAT IF WE NEED TO MAKE AN EXTRA COPY WE CAN ONLY DO IT AT HONDA?
stitos2k Aug 28, 2008 06:32 AM
Pretty much... btw turn off the caps.
6speedftw Aug 28, 2008 06:41 AM
Yup, pretty much all new cars use an RFID chip embedded in the key to start the cars now. It's to prevent someone from making a copy of your key and stealing your car.
DDonovan Aug 28, 2008 11:15 AM
Exactly, if any other key (one that someone cuts) is used the car is imobilized from what I have read. Each car has a "smart igintion" where the key is recognized.
takeshi Aug 28, 2008 12:25 PM
You can make copies all you want but they won't start the car without the chip. It not only needs a chip but the car needs to be programmed to accept that particular key.
Vanishing Point Aug 28, 2008 12:52 PM
Take care of those keys, the dealer wants an arm & a leg for replacements!
mmm def Aug 29, 2008 05:48 AM
Darn the previous owner kept 1 of the keys for decoration..punk. What's a new key go for?
Chazmo Aug 29, 2008 05:56 AM
Yes, they can run around $100... Check with your closest dealer.
Ks320 Aug 30, 2008 09:52 PM
The normal Honda keys run for around $100 each
The one with the S2000 metal plate costs another 50 to 70 bucks more from my dealer.
On top of that, prepare to pay another hundred or so for the programming :( (very expensive for these things)
UmarS2K Aug 31, 2008 12:57 AM
Be grateful you're not buying a Bugatti Veyron key. From what I read, those b!tches run up to $1,000+ just for the key itself. They charge more for programming them.
© 2026 MH Sub I, LLC dba Internet Brands
