Can You Identify This Bumper
Hey Guys,
Thanks to AE Racer I found out what bumper it is, but Im trying to find out if the Version 2 bumper has been tunnel tested like the Version 1. Does anyone know? I couldnt find info on C-West's website
thanks!
Version 1
[attachment=95581:circuit garage front bumper.png]
Version 2
[attachment=95597:N1 V2.jpg]
thanks!
Version 1
Version 2
Holy cow! Its been massively photoshopped. I knew i was photoshopped but I didn't realize that the contour of the front of the lip was completely changed as well. hmmmm...
Do you need a front bumper that has been wind tunnel tested? That's a deal breaker for you?
Just like some people want the CR lip because they think it looks cool, and other want it because it it has a functional aero benefit.
Hey new member here, thought I would chime in. The previous owner installed some sort of C Zest style v2 bumper, The center duct holes are rounded rather than square (not sure if C West made a variant so). Honestly at first, I didn't like the look at all, but its really starting to grow on me.
Like you said, it's a little less common than the usual amuse/spoon style stuff. And I must say I notice a rather substantial amount of downforce, driving above 80mph or so. Just for your research's sake, I did a highway run one night a few weeks ago, and with the front bumper, 140 is about all it had within a reasonable distance. The front end was planted, with not even a hint of lift. Another note is with the radiator duct, it directs cool air all the way in, almost touching the radiator itself. No matter how I'm driving, the temp gauge doesn't go past 3 bars.
Hopefully this helped!
-Alex
image by toplessfc3s, on Flickr
-Alex
MMAP1, the bumper you have is not a Authentic Cwest front bumper. Cwest never produced a N1 with circular holes.
your bumper is by a company called AIT Racing that has been around since early 2000's. They produce replica, since back then it was harder and more expensive to source JDM parts.
https://www.aitracing.com/CW-Style-F...ter_name=s2000
The bumper will help with front end down force by lifting the rear, making your rear unstable at speeds. This will also cause the car to over steer. These bumpers were designed to be balanced with a wing if you are going to be going into high speeds; or you will notice how fast you will wrap it around a tree.
With a OEM bumper your vehicle should also not go past 3 bars.
Yeah I looked at the uninstalled rear bumper I have as well which says AIT. As far as aero goes, there's nowhere near enough downforce to upset the rear end. And maybe three bars is the norm for the s2k, but I'd bet it still cools better than stock and most aftermarket bumpers.
Thanks for the info guys. The ultimate plan was to use a complete aero system, so the rear would have some sort of functional wing. On a side note, that replica bumper seems to fit quote well. Very surprised
