Cusco/Safety21 5 point roll bar installation!
Old 06-04-2011, 10:03 AM
  #111
imtimduh's Avatar
nice write up, cusco
Old 06-17-2011, 08:57 AM
  #112
Dreaming_S2k's Avatar
A little off topic, but a legitimate question:
I know that these (4 or 5pt) apparently do not fit 06+ S2k's, but my question is why, and what would be needed to make them fit?
Help with this would be very much appreciated. I've tried searching all over the place and can't seem to find any solid info.
Old 06-17-2011, 02:29 PM
  #113
Chris_Lum's Avatar
the floor board on the passenger side is a different shape. People have made them fit by modifying the mounting bracket. There should be a thread somewhere with pictures. That is the only difference.
Old 06-19-2011, 05:06 AM
  #114
^Thanks Chris!
Still loving what you've done with the car.
Old 08-05-2011, 11:54 AM
  #115
soulplane's Avatar
after the install how does it feel driving and do the seats needa be moved up in order to fit the bars or do the seats slide pretty far back, i wouldent wanna be in a tight as space either
Old 08-06-2011, 09:20 AM
  #116
Chris_Lum's Avatar
There's a small compromise in space because of the main hoop legs, so the seats can't slide all the way back anymore.
Old 07-07-2012, 08:47 AM
  #117
nos4you's Avatar
Thanks Chris. Used this as a guideline to install my Mugen roll bar. Only difference is I had to remove the hoops for the Mugen.
Question though, any of you guys have problems with the holes / plates rusting out? Thinking of what to spray. I don't want to spray the bottom with paint, it might be hard to remove if I ever want to remove the roll bar?
Old 07-10-2012, 05:29 PM
  #118
Chris_Lum's Avatar
to avoid rust, i'd just paint the backing plates. powder coat them if you want to go the extra mile, otherwise, rustoleum or any spray paint will do.
Old 08-17-2012, 04:46 PM
  #119
zebidi's Avatar
Is this strong enough to be able to remove the centre member and the OEM roll hoops?
Old 11-03-2012, 12:03 AM
  #120
S2KiChad's Avatar
i have problem where the top of my cusco cage rubs against the soft top bar? anyone else has this problem
Quick Reply: Cusco/Safety21 5 point roll bar installation!
