emanage + wideband
hey is there a way to hook up my wideband o2 sensor
to an emanage blue? it would really help to see my air/fuel readings in my logs. and it would be alot easier to adjust the fuel trims accordingly. |
Yes I did it last month. Being able to data log is great. Took a lot of research on the emanage forums. I used my AEM Uego because you need the anolog oput put from it which is the white wire. You also need the wideband harness for the emanage blue that you can get from mohdparts.com. Plug the harness into the emanage connect white to white and gray from the emanage a/f harness to ground.
Set the paramater settings to a/f 0-5v and you many need to fine tune the voltage readings. You can do so by checking with your wideband. I ended up using 10 and 19 for the 0-5 voltage conversion. |
The FI forum is usually the best place to look
https://www.s2ki.com/forums/index.php?showt...&#entry14398917 |
hey thanks revhi. is it possible to do this with a different wideband?
i have an plx devices m-300. it has the white and gray wires, same as the uego. so i don't see why it wouldnt....? :ponder: |
