Exhaust Piping size for S2000
I wanted to know what would be the largest size piping to put on my s2000. Its N/A with an AEM intake and an invidia test pipe ( I think 63mm). Im going to be running dual. I've searched and i get about an even amount on peoples thoughts on some going 2.5 and the others say doing 2.75-3.00 inch..So I can't make up my mind on 3 actually producing poower or smaller.. I am clueless to an extent. To my knowledge too big is not so good on N/A. But the S2000 motor is not your typical 1.6/1.8 dohc b series motor. Please let me in on your thoughts and opinions. Also should I make a new test pipe assuming if I were to go larger in diameter for better flow thanks...
T1R, Amuse, or Tracy Sports are your best bet. Most reduce at the "Y" from 70mm to 63mm. I believe the T1R is the only one to offer a 70mm testpipe and it comes with it. Even being NA, the S2000 responds well to large exhaust piping. Go with 70mm, you'll get the most out of the system.
Originally Posted by hisownhero,Sep 24 2007, 10:11 AM
I believe the T1R is the only one to offer a 70mm test pipe and it comes with it.
Originally Posted by Turbo-Mafia.com,Sep 25 2007, 03:56 PM
If tuned correctly the single 3" system will work great.
although it seems to work better on F22's.
Originally Posted by Jmeyerink,Sep 25 2007, 08:56 PM
hey man, are you sure the T1R test pipe is 70mm?
krnmike
Member S2000 Classifieds and For Sale
05-16-2009 09:13 PM
Vik2000
03-08-2009 09:56 PM
