Few questions for N/A improvement
Hello,
I am trying to improve the performance of my S2000 F20C motor and i need your help. My build so far.
1) Spoon air duct and spoon filter
2) Koyo Radiator with cooling mods
3) Toda header
4) Berks high flow cat
5) Custom M style exchaust
6) Tuned with Greddy ultimate
My dyno graph is below before and after tuning with Greddy Ultimate. It was on a Dynapack dyno
So as a next mode i was thinking a set of pulleys (like Ralco RZ pulleys from e-bay or unorthodox and a lighter flywheel or clutch kit )
Any feedback if i will gain any hp with a set of pulleys or clutch packet ? Can you suggest me which pulleys or flywheel or clutch packet to go with?
Can you tell me your opinions on what to do next to improve the performance of my F20C?
Thank you very much in advance
Chris
3) Toda header
Chris
To be honest I would not trust any of those ebay pulleys.
I lighter flywheel is going to help free up hp to the wheels. Your not going to see much gain up top but may get 1 or 2. You'll see the biggest gains down low in hp and in torque. This is a very good mod. Will help with acceleration as well.
I believe T1R has just released a pulley kit along with a light weight crank pulley. They are far lighter then the stock units, and should help as well to free up more power.
I believe one of the evasive guys have been running the crank pulley for a while, and a couple people have bought the pulley set, but they've yet to install them. no real reviews yet.
Not sure if the stock crank pulley acts as a harmonic damper on the S, if it does I wouldn't recommend running an aftermarket unit, I just don't think the risks are worth the rewards. Toda makes a lw flywheel for our cars, and so does Comptech, though I'm not sure if its still available.
.02
.02
Well the one evasive dude has had it for some time aparently with no issues.
In regard to the flywheel...I had the toda and would highly recommend it...if not toda then go with fidanza.
I would go for the Ralco pulleys they are really good and my car felt much faster with them. Look at feedback on the ebay listing http://cgi.ebay.com/ebaymotors/Ralco-RZ-Pu...emZ140267707651
I am sure if they caused any issues people would not post so many good reviews.
Good Luck
Good Luck
Good Luck
Good Luck
Originally Posted by Kermdaddy,Sep 18 2008, 08:38 AM
No need to go really light flywheel. Best bang for the buck is get a used AP1 flywheel. Personally I wouldn't want to go any lighter than that.
I still do not understand how people can mod there cars using parts from existing vehicles when the owners of those vehicles use aftermarket parts because they show better gains. It's like the b series guys that get type r header...when the type r guys get aftermarket ones and hget better gains...just dumb in my opinion.
