Hondata Reflash/IMG/Exhaust/headers
I was just doing some research and just wanted to ask if someone here had this set up and instead of using the Toda headers used the J's racing SPL header? If so how was it? Did you lose any hp or any gains over the clam that was made on Hondata(238.5 hp give or tak)
Also i wanted to ask how can you tell if your ECU has been reflashed? Without going to a dyno or anything? |
J's spl yields more power over the Toda. I'm sure someone has done this and can chime in.
you'll run leaner with the j's over the toda if you use it with the hondata reflash.
all header cept toda will run either lean or rich.. but its not so bad..
