how to remove rear window on mugen hardtop?
Former Sponsor
Originally Posted by diverseasyn,Mar 14 2008, 04:55 AM
damn, well i guess im gonna have the painter just tape around the molding/weather stripping when painting then.
to remove the mugen rear lexan window, simply undo the rubber/weather strip from the inside. its that simple.
to re-install, you'll need the rope that came with the hardtop.
the re-install is pretty easy, you'll need 2 people for the install.
if this is your first time installing the window....its kinda tricky...so take your time.
Former Sponsor
Originally Posted by WashabiS2K,Mar 14 2008, 09:50 AM
I think you just need to lift the weather stripping and pop the thing out from the inside.. I'm not quite sure how the bodyshop removed mine, but it wasn't their first time. (they have painted a few other local mugen tops as well). I was there to watch the reinstallation of the top though. They used the uber JDM Mugen string that comes with the hardtop in order to compress the weather stripping and put the window back in.
no, you can do it with thick string. it does require two people to reinstall however.. getting it out is easy, jut pull the lip back on the inside and apply some pressure to that area, it will start to push out and then just work your way around . very easy, and since the window is flexible it shouldn't be that easy to break.
i just reinstalled my last night w/ the rope method... after 15 min and some assistance, it's back on. and please make sure to take it off before they paint, it's the only way. now to clean off all the finger prints
Originally Posted by Luder94,Mar 13 2008, 10:33 AM
...oh, and if you break it, King Motorsports sells a replacement window kit for around $400.
