j's header and 70rr= lean
#42
Originally Posted by .MM,Oct 21 2008, 08:09 AM
even 13.8 is too lean
my car is tuned at like 12.5:1 and it made almost 250whp
#43
Originally Posted by NA20,Oct 29 2008, 10:43 AM
12.5 is too rich for NA.... I bet if your tuned your car to 13.5, you'd see a lot more power...
besides, that 1 point change in AFR, especially in a NA setup, can't be worth more than a few whp..why risk it?
#45
Originally Posted by ShocK,Aug 11 2007, 09:25 AM
Beats me, I've read up a lot in the NA threads and everyone says anything above 13.9:1 is unsafe.
If 13.9:1 was unsafe then why would the major car companies have the car adjust fuel ratio to 14.7:1 when running open loop?
From what I've seen on the dyno 13:1 for N/A is the best place to run for power. Hondata's tune for the AP2 and all of their Flashes for other cars run at 13.1:1 also.
#46
Originally Posted by devs2k,Oct 29 2008, 12:48 PM
13.5 would yield more power; however, I bet he is tuned on 93 octane.. the tuner must account for the fact that the tunee might fill up with 91 (either on purpose or by accident) and in that case, 13.5 isn't all that safe anymore..
Also another fact to remember is every single engine is going to like a different air fuel ratio, also different timing in different rpms and different coolant temps. Tune every aspect of each and your engine will be at max with reliable tuning foundation that will give it a long life. Me personally I go for max and if the engine only lasts 100-150k miles then who cares.
#47
#48
From a racer perspective, yes tune to get every ounce of power regardless of reliability.
From a reliablility stand point, keep it below 13 like Honda did stock. They left a margin of richness for a reason.
#49
exactly.
for an overall street car keep your tune a little more conservative. for the s2000, 12.9-13.1 seems to be the sweet spot.
something also to keep in mind is that any of the legit tuning devices usually have a couple different switches for different settings. you can tune the car on pump gas at a more reliable afr, and then you can tune the car on race gas at a higher afr.
all it takes to pop back and forth is a flip of a switch ( and the right gas in the car ).
#50
I see your point but if your not a racer then why tune at all though? Seriously, why waste money on 5-10hp, just to say you've got a "tuned" S2000 thats going to last 50k miles longer than my car tuned for racing, then your just being a tool, not pointing fingers, just generalizing. If you just want to be looked upon as a "tuner" that sounds lame to me. Race parts are for racing not driving around revving at mustangs. Why buy a J's header and 70mm exhaust if your not racing with it or doing something with it, its a full race exhaust not a street setup. I dunno about you guys but I put the exhaust on my ap1 and couldn't give a shit less about the a/f ratio being a half point off, did the same to my ap2, exhaust systems never melted any pistons.
/rant
/thread
/rant
/thread
