J's racing front and rear calipers
Just wanted to ask if the work emo cr kai F 17x8 +47 and R 17x9 +44 offset would fit the J's racing BBK? or would i have to add spacers or need a larger rim?
more likely have to go with lower offsets. at least a +35 on the front so add a 10mm spacer.
on my fn01rc i had a +35 but i added a 3mm to clear. the rear im not sure...
paper thin clearance:
The rear caliper position is more or less unchanged from stock. No worries there.
More detailed info about the rears can be found here https://www.s2ki.com/forums/index.php?showt...&#entry13088749
I don't know about Works but generally you need at least a 40 offset or lower I doubt that a +47 will work with out spacers. However depending on spoke design / face other offsets will work. The real problem is what are you going to do with your fenders????
For more information about Cobalt replacement pads for J's Racing / Endless 6 piston calipers please click the link https://www.s2ki.com/forums/index.ph...f=107&t=624949
It depends on the spoke design and everything, but I think for Spoon calipers you need a +59 offset to clear w/ Work Emotions.
There's a whole thread on it in teh wheels subforum.
im going crazy to try to find out the right answer
The confirmed Spoon caliper fitment for Work Emotion CR Kai is 17x7 +42 offset w/ +6mm spacer. J's calipers are a lot larger. The offset needed depends on the spoke design of the wheel as stated above which is why there are so many different recommended offsets.
https://www.s2ki.com/forums/index.ph...ic=338881&st=0
Originally Posted by Brian_s2000,Sep 1 2008, 12:32 PM
work emotion forged 17x8.5 +59 to clear the spoon.
