S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   JDM Tuning (https://www.s2ki.com/forums/jdm-tuning-148/)
-   -   J's catch can hit the hood? (https://www.s2ki.com/forums/jdm-tuning-148/javascript-catch-can-hit-hood-605330/)
lautll421 Jun 16, 2008 05:38 AM
Hi Guys...i just installed my J's catch can but after i screwed the cap back on i just managed to close the hood but it is still so high that the cap makes the hood bulge up after i forced the bonnet closed, is the fitment really that bad or is there something i didnt do right?
slightly2ned Jun 16, 2008 11:18 AM
I say check all the brackets for the catch can. Then if that doesnt help, adjust the 4 rubber nubs that the hood sits on. You can raise it or lower it.
leester01 Jun 30, 2008 12:26 PM
Yup,the ones I've seen hit the hood.
When Bjeoung had the problem with his J's catch can hitting his hood I thought maybe it's because he doesn't have the J's hood.We thought maybe the J's hood has some special clearance in that area but I see you have the J's hood so scratch that idea.
I've also heard rumors that this is a problem with the old type (with J's emblem) that has been corrected with the new type (J's sticker no emblem)
Which version J's catch tank do you have?
Can you post up some pictures?
GoTuningTommy Jun 30, 2008 12:31 PM
We also had problems with the Mugen and ASM hood. Only solution was to pull the L-coupler off the reservoir cap and run a longer hose from the radiator directly into the reservoir tank.
lautll421 Jun 30, 2008 02:24 PM
^^^any pics to show me how to do it? not eactly know what u mean. Also i have a standard hood
leester01 Jun 30, 2008 02:33 PM
Oh I thought the car in your Avatar was yours.
What Tommy is saying is remove the little plasttic elbow on the oem catch tank cap and just stick a flexable hose through the hole in place of the elbow or run no cap at all
-LAW- Jul 1, 2008 08:43 AM
I'll try and install mine maybe this weekend... we'll see if i'll have the same problem. I have the newer version J's catch can...
:thumbup:
tbtak Jul 2, 2008 05:18 PM
Mine fit, I just used 1 bolt and turned the unit a little towards the engine and bolted it down and it shut.
I have a Seibon CF hood and it clear's, tight but it clear's
https://cimg1.ibsrv.net/gimg/www.s2k...e5e566ad64.jpg https://cimg0.ibsrv.net/gimg/www.s2k...8c89fe7a30.jpg
slightly2ned Jul 3, 2008 01:31 AM
Damn I want this part! I have a J's Type-V hood & would love to test to see if it rubs.
© 2026 MH Sub I, LLC dba Internet Brands
