J's fender brace
I just got the js fender brace and the instructions only come in japanese
Anyone know how to install it? Im looking at all the parts and can't seem to figure out where some brackets go. I know how its bolted to the fender by the looks of the photo.
Please any help would be greatly appreciated with a free honda oil filter for the s2k!. Thanks!
when I did mine on my rsx, I had to take off the fender first, and the door.
they also come with the special bolts that hold the fender bar from the frame.
Hope this pic will help your install.
if you look close, you will see the black bracket that is sticking out from a hole.
that bracket will hold one of your supported bolt.
a bolt that is close to the headlight is the special bolt that needs to be supported
by your body frame.
by your body frame.
Originally Posted by 161MPHTOPSPDS2K,Mar 27 2008, 09:06 PM
Thanks for your photo. It gives me somewhat of an idea.I will see how its suppose to fit over the weekend.
you should do fine, just make sure you line up the doors correctly so
that you can open and close the doors without problems.
