J's racing specialist
Just wanted to know if these items would fit onto my car before i go with the go ahead. My car is a 07 with the j's racing kit. Engine wise its stock. So if you guys could help me out witha YES or NO beside each item that would be great
Thanks Here the items: J's Racing Engine Torque Damper & Strut Bar J's Racing Strut Bar (Rear) J's Racing High Pressure Radiator Cap J's Racing Low Tempurature Fan switch J's Racing thermoswtich J's Racing SPL thermostat J's Racing SPL Engine Magnetic Drain Bolt Js Racing Oil Cap J's Racing Carbon Cooling Plate J's Racing SPL Valve Cover J's Racing Type-S Carbon Air Duct for Stock Air Box J's Racing Tsuchinoko Intake J's Racing Titanium Shift knob - Ti Blue J's Racing Rear Lower X-Beam Bar Js Racing S2000 SPL Exhaust Manifold Spoon Diffuser Spoon Sports Front Cross Beam Bar Spoon Sports Rear Cross Beam Bar Cusco Floor Bar/Chassis Reinforcement |
i'm not an expert, but if you get j's type-s carbon air duct for stock air box there is no need to get j's racing tsuchinoko intake, unless your just asking on all products. but i would have to assume they would all still fit. so
J's Racing Engine Torque Damper & Strut Bar -yes but get LHD version otherwise you'll hate it J's Racing Strut Bar (Rear) - should but i hear its pointless J's Racing High Pressure Radiator Cap - yes J's Racing Low Tempurature Fan switch - yes J's Racing thermoswtich - yes J's Racing SPL thermostat - yes J's Racing SPL Engine Magnetic Drain Bolt - yes Js Racing Oil Cap - yes J's Racing Carbon Cooling Plate - yes J's Racing SPL Valve Cover - yes J's Racing Type-S Carbon Air Duct for Stock Air Box - yes but get either or J's Racing Tsuchinoko Intake - yes but get either or J's Racing Titanium Shift knob - Ti Blue - yes J's Racing Rear Lower X-Beam Bar - yes but may get in the way of the spoon/cusco not sure though Js Racing S2000 SPL Exhaust Manifold - don't think so only up to MY03 Spoon Diffuser - not sure thought it was made to be used with their S-Tai rear bumper but may be wrong Spoon Sports Front Cross Beam Bar - should but may get in the way Spoon Sports Rear Cross Beam Bar - should but may get in the way Cusco Floor Bar/Chassis Reinforcement - should but may get in the way *keep in mind i havn't owned these parts or tried just basing on what i've read and remember so wait for more responses or do more research. |
Okay, you don't need a carbon air duct if you're getting the tsuchinoko intake. The tsuchinoko intake is a full replacement for the stock airbox, and since you have the j's racing kit, make sure you get the tsuchinoko intake for the type-s bumper. J's racing rear lower beam will conflict with spoor rear cross beam bar, so choose which one you want. Oh and the intake will need a slight modification to fit. I forget why. It has to do with a slight difference in the 06+. Other than that, you're good to go.
Thanks Here the items: J's Racing Engine Torque Damper & Strut Bar J's Racing Strut Bar (Rear) J's Racing High Pressure Radiator Cap J's Racing Low Tempurature Fan switch J's Racing thermoswtich J's Racing SPL thermostat J's Racing SPL Engine Magnetic Drain Bolt Js Racing Oil Cap J's Racing Carbon Cooling Plate J's Racing SPL Valve Cover J's Racing Type-S Carbon Air Duct for Stock Air Box J's Racing Tsuchinoko Intake J's Racing Titanium Shift knob - Ti Blue J's Racing Rear Lower X-Beam Bar Js Racing S2000 SPL Exhaust Manifold Spoon Diffuser Spoon Sports Front Cross Beam Bar Spoon Sports Rear Cross Beam Bar Cusco Floor Bar/Chassis Reinforcement J's Racing Strut Bar (Rear) YES BUT THE STOCK IS FINE J's Racing High Pressure Radiator Cap YES J's Racing Low Tempurature Fan switch YES J's Racing SPL thermostat YES J's Racing SPL Engine Magnetic Drain BoltYES Js Racing Oil Cap YES J's Racing Carbon Cooling PlateYES J's Racing SPL Valve Cover YES J's Racing Tsuchinoko Intake YES BUT NEEDS MODIFICATION J's Racing Titanium Shift knob - Ti BlueYES J's Racing Rear Lower X-Beam Bar NEVER HEARD OF THIS FOR REAR Js Racing S2000 SPL Exhaust Manifold YES Spoon Diffuser NOT SURE FOR AP2 REAR BUMPER |
No no i understand that there is 2 different intake system listed.. im just asking if either or will fit
and thanks for the info david |
I would check on the valve cover, I think it's different for 06+, I don't know if that will fit
everything will fit except the J's Racing Low Tempurature Fan switch,
J's Racing thermoswtich, J's Racing SPL thermostat. Also the intake will need modification, you can stop by my house and i can show you the intake. and the other things on my car. |
thermos will fit, and everything. the only thing that won't is the fan switch
I was wondering if anyone here knows if someone here has a j's racing exhaust on there s2k that is 06+.....I've been reading different answer..if someone can please clear this up for me that would be great
thanks dave |
| All times are GMT -8. The time now is 12:13 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
