S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   JDM Tuning (https://www.s2ki.com/forums/jdm-tuning-148/)
-   -   J's tow hook install (https://www.s2ki.com/forums/jdm-tuning-148/javascript-tow-hook-install-361186/)
ruexp67 Feb 15, 2006 05:05 AM
Does anyone have instructions on installing a front J's tow hook?
c17r15 Feb 15, 2006 05:32 AM
I need the help also....can't seem to find the holes.
hopefully it's not because of my bumper.
bluesaint Feb 15, 2006 07:48 AM
u have to remove ur bumper first. then remove the front bumper support beam and you'll see your holes.
c17r15 Feb 15, 2006 07:57 AM
Is this where the hook bolts up to?
(hope you don't mind me borrowing your picture I Don't Wait..)
https://cimg4.ibsrv.net/gimg/www.s2k...45cc412da2.jpg
c17r15 Feb 15, 2006 03:13 PM
for future references:
1. the easiest way to do this is to remove the bumper. you can also install the tow hook without removing the bumper by removing your factory air guide/cooling plate.
2. the bumper support beam does not have to be removed. on the driver side there is a clip securing the bottom splash shield to the chassis that has to be popped out by using a long flat head.
3. with the clip pulled you'll gain access to the holes the tow hook mounts onto.
4. reinstall.
the following only applies with the amuse r1 bumper:
the tow hook has to come out from the right side vent, i couldnt get it to clear the center vent.
from what i can see even if the hook clears the center vent the tow hook will still be useless since the hook will sit flush against the top of the vent and won't stick out past the bumper.
Brownergy Feb 15, 2006 04:31 PM
More importantly, post pictures of your rigs/trailers that you'll be using to Tow.
s2k_beyond Feb 13, 2018 04:27 AM
The tow hook didn't come with instructions and I couldn't find much besides this old thread. Figure I update this thread with some pics. I cut a hole to pass the tow hook through the plastic, then sandwich the plastic between the beam and the tow plate.
https://cimg7.ibsrv.net/gimg/www.s2k...4e0014c7fa.jpg
https://cimg9.ibsrv.net/gimg/www.s2k...679a1aaf4a.jpg
https://cimg8.ibsrv.net/gimg/www.s2k...dd9d2c75df.jpg
freq Feb 13, 2018 05:49 AM
What are you using for your brake duct intakes? Diameter? 2.5 or 3?
© 2026 MH Sub I, LLC dba Internet Brands
