J's TSUCHINOKO Intake
Old Oct 26, 2006 | 04:40 AM
cuonice's Avatar
Default J's TSUCHINOKO Intake
Can anyone tell me the differences between the "type 1" and "type 2" tsuchinoko intakes?
Thanks,
Aaron
Old Oct 26, 2006 | 10:56 AM
MyEeek's Avatar
I believe that Type I required for the oem grill to be cut/modified in order for it to fit, however, it had a large snorkel opening about 1/4 the size of the ap1 grille area. This version is no longer produced. The Type II is basically the same thing except the snorkel opening is much smaller (shorter in height, but possibly longer compared to spoon's) which doesn't require for the grill to be modified/cut. However, there is no power difference between the two.
Old Oct 26, 2006 | 06:40 PM
cuonice's Avatar
Thanks for the reply. I figured the difference would be something trivial like that.
Old Oct 26, 2006 | 07:21 PM
AlX Boi's Avatar
So the type 2 still requires a new hood or hood cutting on the OEM right?
Old Oct 26, 2006 | 07:39 PM
wuchan01's Avatar
yes it still does
Old Oct 28, 2006 | 01:07 AM
riokong's Avatar
Does it work with the J's street hood. It's got a cut out next to the drop vent.
Old Oct 30, 2006 | 02:38 PM
wuchan01's Avatar
actually i believe it only works with the J's type V hood which has the hump to clear the snorkel, im not sure if you can cut the type S, because the type S has no hump.
s2kslav
Jul 2, 2011 11:08 AM
Biff_Malibu
May 15, 2011 03:58 PM
WindchaserS2K
Sep 10, 2006 07:51 AM
