Magnaflow, Dynomax Exhaust?
I'm happy with my Magnaflow mufflers. Sounds is pretty deep with no real droning at cruising speeds. I cut the stock mufflers and replaced with straight flow Magnaflows, 2.5" inlet and outlet. I then modified the Y-section and had the muffler shop fabricate a true-Y pipe. I am also running a JIC test pipe and Comptech header. It's louder than stock, but definitely quieter than many aftermarket systems.
I've been sc'd since 5k miles, and had the exhaust done around 1k. Sound with just the exhaust and pre-tp & sc, the note was deeper than stock and a tad louder. Addition of the SC changed the tone and loudness. The biggest difference in flow and sound was the addition of the test pipe.
I don't have dynos of pre-exhaust, but pre--post test pipe installation yielded at gain of about 10whp 277whp to 285whp (unfortunately, clutch may have been slipping...after clutch and fw install, 306whp).
Magnaflow with stock oval tips
Refabricated Y-section
Full rear shot
Full rear shot
^ Hi, I saw in your pictures that you're using Offset/Center mufflers, does they still have straight thru pipes please? I think that the Offset/Center mufflers are easer to install than Center/Center.
Thank You
Thank You
Originally Posted by jimbrowski00,Mar 15 2006, 03:32 PM
Which Borla cans did you go with? What would you compare the sound to?
Jim
Jim
The sound is deeper than stock for sure and is more fun that stock IMO. If you have it in a higher gear but are going slow like city traffic then the deepness does seem to drone a little bit but nothing crazy like the Invidia I used to have which droned all day it seemed like. Basically if you're in the "right" gear and not day dreaming you don't get the drone I speak of.
This was just a simple and cheap exhaust mod. I may end up liking it and keeping it for a while but I would bet that I get a true catback (Mugen, Comptech?) down the road along with a test pipe and header but we'll see.
Thank You
Thank You
Question ... why is this in the JDM forum? As long as you're talking about exhausts in the JDM forum, I feel the responsibility to shout out an incredibly expensive exhaust just to piss you off - Amuse R-1000!!!!
Good luck with the build, what is your ultimate goal for the car? Also when checking out exhausts in the range of Mugen/Comptech, check out Supersprint and B&B, as well. Neither is much louder than stock, but both have very nice looks and are dual, good luck!
Gary-Phd,
I live in the bay area as well. Where did you have the work done? Part numbers?
How much did they charge you?
So you have no droaning? I may want to replicate the same on my 02 with a test pipe
Thanks for any info...
Hey water...I'm in Antioch, so if you want to hear my car, just send me a pm.
I had the work done at Mel's and Sons in Concord. They did some work on my TT, but the guy who does my work may or may still be there (forgot his name off hand). The other welders are ok. I paid around $400 for the mufflers, y-pipe, piping, and work. It's not a bad price.
The mufflers were either 14216 (5x8 oval) or 14316 (4x9 oval), 2.5" inlet/outlet, center/center...both are polished SS, $99 ea.
They fabricated the Y-pipe, however, you can buy a pre-fabricated Y pipe (e.g., Magnaflow sells one, and so do Dynomax)...which might be cheaper. I paid $80
This is a 2.5 into 2 - 2.5"
And, no, I don't get any droning.
If you decide to use them, make sure they don't use any crimp bent pipes - insist on mandrel bent only. You can always negotiate the price.
I also had magnaflows cut in. I've received nothing but compliments and am satisfied for now. I'm probably eventually going with a single power increase but this will work for now. here are a couple vids of my car that give you an idea of what they sound like.
Drive by
Sitting still and reving
note, i have a megan testpipe as well.
Drive by
Gary,
Too funny, what a small world. I know Donny the owner of Mel & sons. I've known him for almost 10 years. I will chk in with them. I live in Pits so I would love to meet up with you at some time and chk out your ride. Maybe go for a spin, you have SC on it too right!
I appreciate all the info. I sent you a pm . if you want to shoot me an email that i put in the PM !
Have a good friday!
Have a good friday!
[QUOTE=waterhound7,Mar 17 2006, 10:48 AM] Gary,
Have a good friday!
Have a good friday!
