Rotora MINI Brake
Old Jan 31, 2010 | 06:33 PM
  #21
Suzuka_Joe's Avatar
I've been wanting these for a long time. I just don't know if the spoons are worth the extra $$.
Old Jan 31, 2010 | 06:35 PM
  #22
chuhsi's Avatar
No way these can fit under ap2 wheels without a spacer.
Old Jan 31, 2010 | 07:05 PM
  #23
akilbrid's Avatar
ahh horseshit. Would the spacers need to be huge?
Old Jan 31, 2010 | 09:00 PM
  #24
petawabit's Avatar
Originally Posted by tantheman,May 4 2007, 07:15 AM
On the look out for rear BBK set up that would work in conjunction with the E-brake.
Tan
Wilwood rear big brake kit, 1 piston, works with e-brake
Old Feb 1, 2010 | 09:41 AM
  #25
Fyrestrike's Avatar
Or you can spend just a bit more and get the bigger kit that comes with big calipers and front/rear rotors
https://www.s2ki.com/forums/index.ph...f=107&t=761045
Old Feb 2, 2010 | 08:28 AM
  #26
Voodoo_S2K's Avatar
Except the OP is looking for something that will fit under OEM wheels.
Old Feb 2, 2010 | 08:48 AM
  #27
Dressed2Kill's Avatar
"S2kitt" has this brake kit on his car. I know he had to add 10mm spacers for the brakes to fit with his 5zigen FN in 17x8 with a 45 offset.
Old Feb 2, 2010 | 09:14 AM
  #28
Fyrestrike's Avatar
The Mini brakes do not fit under OEM wheels....
Old Feb 2, 2010 | 12:12 PM
  #29
00wreckedS's Avatar
I have the mini set, and the fronts will need a spacer
Old Feb 4, 2010 | 11:46 PM
  #30
hrcrothmans's Avatar
The only trully BBK that fit into the OEM wheels without spacers is the tarox.
And by the way the tarox is a billet caliper which is better than monobloc
i have installed it myself and it is fantastic...
small photo of the rear 330mm using OEM caliper
and photos of the front kit 320mm with the billet 6 piston caliper
