S2000 Touge Coilovers
Hey everyone! So the amuse s2000 R1 and the first gen J's racing s2000 are my favourite s2000s of all time. I really like how these touge oriented s2000s look and peform. Sadly i can't afford the Amuse coilovers nor the J's racing coilovers and i was looking at some alternatives. The only s2000s that i remember seeing on Hot version that are similar to those two are the MCR s2000, Arvou S2000 and the Seeker S2000. Does anyone know of any other JDM tuners that tunes s2000s for the touge or where i can get any of those coilovers and how much they will be?
You would be better off getting some racing coilovers such as Motion Control, Penske, Ohlin, or Moton. Do some research in the Racing forum. If you can figure out what you want, look for some used ones. I have Ohlins and bought them used. They are a far better shock than I am driver.
Really one of the more important things to consider with a coil over is can you get it rebuilt locally or semi locally. Every damper will have to be rebuilt at some point. The Amuse cars use Bilstein dampers, J's uses dampers built by Showa. Which you probably couldn't get properly rebuilt in North America without getting the specs from Amuse or J's.
I would say the two best options at a lower price range are the Bilstein PSS9 (reasonably soft spring rate and high quality rebuildable dampers, also free rebuilds for life if you buy them brand new I believe) and the KW V3 as you mentioned. You can't really go wrong with either. If you have more to spend the Ohlins DFV are a great option. I will be using them on my car specifically for mountain driving and occasional track visit.
The dampers are only one part of the package that makes those cars great so don't think your car can't have a comparable suspension setup for a reasonable price. It is the overall setup of those cars that really make them shine, plus the S2000 is just pretty f@#king awesome to begin with.
Originally Posted by garykoo' timestamp='1388790524' post='22948953
[quote name='andrewhake' timestamp='1388789070' post='22948916']
[/quote]
That's really true, i'm not looking to really push to the limit on the touge but just do some spirited driving, but of course i still don't want it too stiff for the same reasons you mentioned. i think most of the time I will be testing my skills and different setups on the track just to be safe and plus there aren't that many mountains near me so its not exactly a frequent thing. But do you think that having a stiffer springs for the pss9 will be comparable to something like the KW v3 or other coilovers in the 2k range?
I don't think the KW v3's are very stiff really. They are 456lb springs all around I think (around 8kg/mm), so that would be a good setup for the street. The PSS9 have pretty similar rates to the CR suspension so definitely will work well on the street. You probably wouldn't want to go dramatically stiffer on the PSS9 without revalving. Yes I would say they would be comparable with a revalve.
There are quite a few who I have talked to both on the forums and in person that use stiffer 70mm id swift springs with success. Ive spoken to bilstein myself and they mention that they wouldnt go higher than an 8k spring on the stock valving. Ive got the bilstein pss and they feel similar to a stock CR, it definitely does have more rebound/compression versus the stock ap1/ap2 setup, they are also very compliant on broken mountain roads as well.
