Toda ITB's
#23
1 Post
ITBs, hell any heavily modified car, is going to come down to proper tuning that should be given. You can't pass annual emissions in any state that checks ODBII with an S2000. Something Race Miata didn't probably have to worry about on his Miata. I'm also wondering how many different areas you drove your Miata. I had no problems with mine around my area but when I took it to an area with much higher elevation, I found that adjustment was needed. The colder climate and higher altitude for some reason made the car hiccup at higher RPMs. I am getting better gas mileage but that' due to a better tune IMO then ITBs themselves.
#24
1 Post
Originally Posted by white_S2000@16,May 11 2005, 10:48 AM
sorry, my vocabulary isnt as technical as it should be and is hard to follow look at the pick i posted up the red line i drew over the twm itbs is the "runner length" hopefully you have a better wod for it but looking at teh pic i put in of the haywards im wondering if the twm are actally longer as i dont have measurements for either im just going by pictures. Also the reason i though haywards are made by jenevey is because on jenevy's site tehy have the EXACT ones hayward does so i thought jenevy was supllying hayward theres,maybe im wrong could you clarrify this??
#25
1 Post
Damn, I have to read all the way through. Here is the difference between Hayward's setup and Jenvey's (this is all info from when I was researching last year). Hayward's come with a set of Pico Injectors, Jenvey's no injectors. Hayward's include an S2000 specific throttle cable hook up, Jenvey's you have to fabricate one. Haywards, come assembled with a vacuum tree, for brakes, map, etc, Jenvey's don't. Hayward's has a different location for the water outlet (stock location), the Jenvey's is moved closer to the manifold/head flange.
#26
1 Post
BTW, I just checked TWM website the $2185 price is without injectors. Hayward's price includes injectors, so you aren't really comparing apples to apples here. If they are charging $200 per injector you are looking at pretty much the same price.
#28
I'm not sure about the other manufacturers but TWM seems to provide pretty good service. When my original used decade-old TWMs was too small for my application, Gary let me traded them in for a new set with bigger bores plus new fuel-rails. Getting serviceable parts form him was also not a problem.
