Wheel fitment for J's wide fenders/ rear overfende
Looking to stuff a NON-STAGGERRED set of 18x9.5 wheels on my car.
J's racing front wide fenders and J's rear over fenders. What offsets/tire sizes should i be lookign at? Thanks! |
nobody? i'm looking to order my widebody/wheels this week
17x9 +22 X4
Im sure you can fit at least 18x9. how much bigger are the J's fenders?? if there like 50mm all around im sure you could slap some 18x10s all around with the right offset.
you can stick 10s on a stock bodied s2k with the right offset..
J's front fenders= + 40mm each side
J's rear over fender= +25mm each side |
so it isnt a matter of what you can fit, but what do you want to fit?
i'd like to run 18x9.5s all around, what would be the best offsets if i cut the rear fenders?
+40 to +35 will give you a little bit of room to be on the safe side... the furthest will be +30 and it will start to be on the rubbing side, unless you have camber kit and run aggressive camber... it all depend how aggressive you run your camber....
I think +40 to +35 will give you the best of both world... |
1 Attachment(s)
