ZEAL Function B6
Please someone chime in, im having issues with this suspension :( im getting a weird noise from the rears as if the top bolts were loose but everything is on tight, PLEASE HELP!
ttt
too much preload? Bottoming out?
Originally Posted by VeilSide AP1,Sep 18 2008, 07:00 AM
I think i figured it out, i will take it apart today and see if i am correct, Thanks!
Originally Posted by lordbyron,Sep 21 2008, 07:58 PM
update?
in for an update.
if this is the same as what happened to mine, a rebuild isn't that expensive. $100 per corner. if its the shafts, $90 per shaft.
what is the results?
if its on pillowball mounts, im guessing the damper body is not bolted onto the top hat tight enough. many ppl are afraid of over tightening which they should be cause it can ruin the damper, but if there is play, it will clunk under suspension travel
