FS: F22 Complete Motor (Rod Knock)
Means of Contact: PM/post a reply
Description: F22c complete motor removed from a 2007 S2000 w/ 94,000 miles. I purchased the engine with a spun cam journal. I replaced both cam shafts, timing gears (all three) and all five cam towers with stock replacements from Inline Pro. While the head was off, had the valves checked, none were bent or burnt. The car's original head was replaced under warranty, but I am not sure when. I checked the bores, they were OK with no scoring. I ran a compression test while the engine was in the car, had between 220-225 PSI in each cylinder (with the motor cold). After the head work, the car had a knock. Inline Pro diagnosed the knock as a rod knock (low oil pressure), and thought that may have caused the cams to spin. The engine has all new gaskets, I have receipts.
Included:
I can help with delivery, but I do not want to ship. I am leaving town this weekend, would like to have the motor gone by then.
Please contact me with any questions
Price: $1350 OBO
I will try to get some pictures up later today
Included:
- Complete head and block, from oil pan to valve cover
- Starter
- A/C compressor
- Alternator
- Intake Manifold (w/ throttle body)
- Fuel Injectors + Rail
- V-TEC Solenoid
- Timing Chain Tensioner (Did not make any noise when the car ran)
- Exhaust Manifold
- Coil Packs
- 2 sets of used NGK IR plugs
- Valve cover
- Wiring Harness (has a broken connector where it plugs into the ECU)
- All sensors
- Clutch/Flywheel/Pressure Plate
Price: $1350 OBO
boostedAT9K
NYC Metro Stock Exchange
06-17-2012 01:19 PM
boostedAT9K
06-17-2012 01:18 PM
