Lovely Misfires
MAP sensor replaced, reset ECU, drove around... came back on after awhile.
Came home installed both new O2 sensors... reset ECU, drove around (but not much) still hasn't came on yet, still have to drive some more though
After some more driving, it came back on...
The Cat 02 that I pulled out was so cruddy and caked with different color soot that I really thought that that was the case.
Bummer, the hunt continues.
My guesses:
Alternator (best way to check to see if rectifier has gone bad?)
Battery
Wiring harness
ECU
Injectors (but would be pretty random that all 4 are throwing misfire code?)
Knock sensor?
My guesses:
Battery
Wiring harness
ECU
Knock sensor?
drivability, not really. Although does seem a bitttt sluggish (could be in my head). But I do get popping from exhaust. Sometimes I get a little hesitation leaving a stop after idling for awhile.
Ive been having the same issues only I have an audible stutter or misfire on a cold idle. Very faint but its there. Ive adjusted my valves and changed my plugs so far. I'm about to heaed to honda today for an induction clean to see if that handles the issue
So just checked what the codes are this time after I installed the oxygen sensors:
- cyl 2 misfire detected
- cyl 3 misfire detected
- cyl 4 misfire detected
- random / multiple misfire detected
Hmmm... now cylinder 1 is not misfiring, damn gremlins
Like I mentioned before if your dash flickers its probably your alternator. S2000s gauge clusters don't typically flicker. Do you here a clicking also when the dash flickers?
Don't hear a clicking, and I wouldn't even consider it a flicker, it doesn't happen often. I try to purposely make it flicker and it won't when I try to show people. Like when the air pump comes on when I first start it I get a flicker I guess, is that at least normal?
