S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   New England S2000 Owners (https://www.s2ki.com/forums/new-england-s2000-owners-9/)
-   -   source of rodent smell (https://www.s2ki.com/forums/new-england-s2000-owners-9/source-rodent-smell-1209028/)
moran Aug 1, 2021 07:25 AM
I'm experiencing a strong almost overpowering rodent smell in my 2003 S2000 that is likely a mouse nest or mouse urine or worse. I'm unable to find the source and wondered if others having experienced similar invasions have determined the likely location of the deposit from which the smell is emanating? Both actual experience and likely suspicions will be helpful. Thank you.
NNY S2k Aug 1, 2021 11:56 AM
Maybe a dog or cat can sniff it out for you.
moran Aug 1, 2021 05:19 PM
Hadn't thought of that. My dog already chases squirrels, chipmunks, etc.
EOE Aug 2, 2021 03:32 PM
- Pull out the trunk lining, look behind there. Where the fuel tank is. It’s what the softop rests on.
- Seats are easy to take out, so you can do that or just turn on your phone’s video (with flash on) on your iPhone and record what’s under the seat. Review.
- Pop the hood and look under your clutch and brake fluid reservoirs. Do the same around battery area.
- Take the tool kit out, now take a look at the very bottom of your trunk. Is it warp, soggy or if you push down does it sound sloshy? If YES then your softop drains are leaking. There’s also a trunk/rear bumper vent seal known to leak.
FOM09 Aug 4, 2021 10:19 AM
Lot's of rodents like the heater core also.
JackTs2K Aug 5, 2021 07:40 AM
I knew of an S2000 that was poorly stored (outdoors) for two years. Rats built a nest on top of the gas tank. The tank was corroded from rat urine, hoses were chewed, and the only way to get to the tank was to drop the subframe. Cross your fingers.
Psyrus Aug 11, 2021 06:44 PM
That spot on top of the tank under the soft top tray seems like a go to spot for the mice. I would also look under the hood passenger side right below the windshield where the OEM air filter lives. Look in the places where we have easy to chew insulation, plastic and sound deadening
material.
YoG628 Oct 17, 2021 04:28 AM
I've seen quite a few rodent nest under windshield/wiper cowl
blueosprey90 Oct 22, 2021 01:22 PM
I'm suffering from this problem as well. Car was sitting in my garage from mid July until mid October. I have to do further investigation. But strongest smell of dead carcass seems to come from under the windshield washer bottle. Perhaps between the fender and the inner fender lining. I just hope it is a mouse and not a groundhog. https://www.s2ki.com/forums/images/smilies/smile.gif
© 2026 MH Sub I, LLC dba Internet Brands
