I-78 CONSTRUCTION ALERT!
Hey guys -
I think there are a bunch of you who will be traveling out I-78 to FC and the track event at Beaver Run. I went to Summit Point this past weekend and there are some pretty bad construction delays on I-78. There are 2 areas between about exit 50 and exit 30 where it goes to one lane for several miles and can definitely be a little slow going. Westbound was not as bad - maybe 15-20 minutes but it could be worse when you go. Eastbound from mile marker 35 to 30 iirc was worse. Took over an hour to go 6-7 miles. :banghead: Just figured I'd give you the heads up. |
thanks for the head up...but, some of us will be taking 80 west.
jay |
Interesting ... I will go on line and see if I can find anything about the road work from the pa tpk authority... perhaps an alternate route would be in order ?
it also depend on time of the day. for us, it's going to be about little after 9:00 am, we will pass this area. considering most traffic will be on east bound, I think it should be ok.
OK -- got it -- we will take 80 west to 287 south to I-78, thereby totally avoiding I-78 from intersections 30 and higher . The distance is identical either way.
Thanks for the heads up !! |
Let me clear this up
If I Recall Correctly = iirc I'm referring to exit #30 in PA - a potential route to BeaverRun - I also posted as a general notice for anyone considering travelling in that direction/area. |
The problem is that the second choice adds 30 miles to the trip.... :confused: Damned if we do or don't. Eliot |
The way out might not be too bad - depending on time of day but you never know.
The way back was definitely worse. There does look like a decent local route detour - which could be a nice drive anyway I'd check for the exact location - I assume the PA DOT posts construction info - then get busy with google maps - I only had my Atlas and a bad attitude at the time. |
