Pfab Turbo Build
Hey everyone, im trying to join alot of metro people by boosting the s2k, i was wondering if theres anyone around has the pfab kit or experience with it and also if there are people with 06+ that are boosted that i could talk to about my build and theres. also my goals are to to be a daily driver and be around 400whp with the abilties to go to 475-500 in the future..heres a list i put together for my build am i missing anything?
PFAB Topmount Log manifold PFAB Stainless steel downpipe PFAB Stainless Steel dumptube Garrett T3/TO4E Turbocharger TiAL 38mm Wastegate TiAL BOV PFAB Stage 2 intercooler PFAB Intercooler piping kit 1000cc ID's Hondata FlashPro ACT Heavy Duty Performance Street Clutch Kit SOS Pillar Pod AEM AFR and Boost Guage ScienceofSpeed 4-Bar MAP Pressure Sensor heres some pics from my cellphone http://img3.imageshack.us/img3/5854/img00422q.jpg http://img687.imageshack.us/img687/6707/img00403i.jpg http://img69.imageshack.us/img69/5300/img00423.jpg http://img31.imageshack.us/img31/1207/img00427.jpg |
I'm pretty sure no one in Metro has the log kit. I run Pang's equal length v-band setup - and joeyballs has his divided equal length mani.
First and foremost - are you planning on running stock cr or a headgasket? Who will be tuning this? At a quick glance, you will also need: Oil feed and return, fittings etc Walbro 255 ARP Manifold Studs EGR block off plate Boost Control Solenoid Heat protection for fusebox/battery or relocate |
i plan on going to evans tuning, and was also gonna recloate battery to trunk and rotate fusebox 90degrees and wasnt planning on changing headgasket..and i also seen that inlinepro just came out with a return style fuel system kit, was thinkin of adding that to the list as well
also i dont need a block off plate since im 06 dbw correct?
If you want 500+ in the future you have to get that return kit.
Yes no block off plate. |
i still don't understand why people put logs on such a good motor with a high flowing head :(
because they are cheaper, will not break and don't usually require relocation of the battery/fusebox
sure, tubular manifolds flow better, but they are not without trade-offs |
theres more than one reason not to have exhaust gasses from different cylinders firing AT each other.
but for the gasket situation , it seems 50/50 with people saying you need it and pple you saying you dont, ip recommends it but mase doesnt..any input?
