Request to all my cutsomers
Trying to keep track of who's done what. So if you can remember what I did to your car, and the approx mileage it was done, post it here or send me a brief PM.
Thanks for keeping me nutz :) |
10,500mi. Eibach Springs, Clutch fluid, Axle TSB, 06 Radio Door.
I don't think there's any part of RED you didn't touch. ;)
Just for the recent work, SC repair, injectors, LW pulleys, and Defi Guages. RED had around 49,000 miles. |
54k: TCT, complete fluid change, F/R pads, throttle link adj. clutch adjust.
98k TCT#3, front pads, brake/clutch fluid. 100k Once Over (3/07) |
21,000mi. Espilar Springs, Valves, Clutch fluid, Diff fluid, Axle TSB, 06 Radio Door.
i think thats all.... |
32,000ish
Valve Adjustment Axle Nut Tightening Replaced Cabin Filter Replaced Clutch fluid |
36,000 Miles - Timing Chain Tensioner, Clutch fluid, Top Down Rollling Mod, Cabin Filter, Clutch pedal adjustment. Next Appointment - Once Over (waiting on response for appointment date)
15K= Valve Adj., Once over, Cabin filter.
https://cimg3.ibsrv.net/gimg/www.s2k...1bd993846f.png
Valve Adj /clutch adjust 10,000, Chain tension Axle Nut Tightening,Supercharger 41,000,act package ,crank case vent,gauges 51,000. You also made a house call as well ,which i'll never forget |
How's this?
Pick what you did from the list.... 04.07.04 51 picked up car 7.04.04 3700 Oil,Filter,Differential Oil, Hub Nuts lubed torqued 10.04.04 5000 Trans Oil to GM FM Synromesh 12.04.04 6000 Wheel Alignment 1.05.05 7000 Oil, Filter, K&N Air Intake 3.05.05 9000 Synthetic Oil, Filter, Differential Oil, Inspect brakes 3.05.05 Paint Calipers, Mod Slave Cylinder 3.05.05 9500 Interior Swap to Tan w/1500miles 4.05.05 10500 Trans Oil to Redline MT90 5.19.05 12000 Oil/Filter/Valve Adjustment/Retainer Inspection Brake Inspection Cabin Filter Replacement 8.07.05 14350 Cam Chain Tensioner 9.24.05 15750 Oil/Filter Clean & Oil K&N Air Filter 9.25.05 15850 Brake Fluid to Super Blue/Test & Inspect Pads 9.28.05 15950 Rear tires RE050/balanced & 4 wheel alignment 9.29-10.02 16000 through 17200 Fall Colors 05 11.11.05 18200 4 Wheel Alignment 11.28.05 18900 4.56 Gears /Diff swap LE 607 Gear Oil 01.08.06 20050 Oil/Filter/Gear Oil LE607 03.27.06 21800 New K&N Air Filter 07.04.06 24070 RP/Axial Short Shifter 07.22.06 24450 Oil/Filter 08.06.06 24950 Inspect brake pads front & rear - 70% 08.07.06 25050 cabin filter; C's Style Shifter; Pulley's; Valves Inspect & Adjust 12.10.06 27950 Oil/Filter: TRANS OIL to HONDA's New MTF (white cap) 12.31.06 28250 Berk TP 03.03.07 29050 New O2 Sensor in TP :D https://cimg6.ibsrv.net/gimg/www.s2k...204fbc25ad.jpg |
