New York - Upstate New York S2000 Owners All areas North of I-84 (Port Jervis to Putnam Lake) in New York State
CR Wing install on a non CR trunk
Old 07-26-2017, 04:18 PM
shiv's Avatar
Originally Posted by lolls
Are there any markings I can go by on the inside of the trunk that could be used to drill these holes ?
For the CR wing im not entirely sure. There are markings on the far edges of the trunk but they will not be of use since the cr wing mounts are more center oriented. Measuring tape and pencil may be the way to go. Does the CR wing have 2 studs per mount?
Old 07-26-2017, 05:51 PM
Bugsy's Avatar
Nope, it is definitely 399$
frightening
thats what my upgrade to 3rd party hosting from Photobucket comes to.
If you know of how to do it cheaper, I'm all ears
https://www.ghacks.net/2017/06/30/ph...hosted-images/
Old 07-26-2017, 07:06 PM
lolls's Avatar
3 holes have to be drilled on each side i believe.
Old 07-26-2017, 08:04 PM
shiv's Avatar
Ok so heres how I would do it. Measure the width of the trunk and mark the vertical centerline of the trunk(pencil it in). Then position the wing as far back as you prefer and then mark a horizontal line. Then it's a matter of marking your mounting points (making a template helps, especially with wing stud location) And drill baby drill. This is how I mounted and installed my hood vents. And it worked out well. Penciling everything in helps when measuring before final drilling.
Old 07-27-2017, 08:15 AM
Bugsy's Avatar
Inspired me to put on the wing trunklid and take some pics.
the key is locating the front studs/(bolt holes-where my fat finger is pointing) so they fit evenly in the radius where the inner trunk skin isn't. The rest fall into place.
Don't forget the other cr reinforcements as the thing is heavy and the skin is thin. It'll also move side to side if you don't put in the wedges.
Pics to follow.
Old 07-27-2017, 08:18 AM
Bugsy's Avatar
Old 07-27-2017, 08:23 AM
A 2
A 2's Avatar
Old 07-27-2017, 10:24 AM
NNY S2k's Avatar
Great post Jeff, I'm sure it'll help those wishing to do the same.
Levi
Old 07-27-2017, 04:44 PM
lolls's Avatar
Now I noticed there's like an extra piece of metal where you were pointing to Jeff. How did you get that in there? Or is it just a piece of metal that you put in place? This is starting to look like a project I don't think I'm going to be able to handle without taking it to a professional or a shop to do it. And without specific directions no shops gonna want to handle it especially if they have to drill holes. My only bet is to get a hold of someone who's put one on their car and see if they would be able to do it for If not I'll see if I can return the wing or sell it.
Old 07-27-2017, 04:48 PM
Bugsy's Avatar
I made that.
I think I saved a template. I'll look
Dat_Jerzy_Dude
11-30-2017 11:46 AM
lolls
07-27-2017 09:27 PM
MRPHIPHI
04-20-2017 07:08 AM
jsdude
09-10-2015 01:17 PM
Suzuka_BlueS2K
02-06-2014 11:51 AM
Quick Reply: CR Wing install on a non CR trunk
