Jake's Track Car Build
4 Attachment(s)
As some of you may know i picked up another s2000 a few weeks back. Long story short, the car dropped a valve and the owner decided he was finished putting money into it. He decided to part out the drag car since it had a lot of big money parts into it. After bugging him for months he finally sold me what was left, basically a roller. So here is what i have; A fully caged MY2000 roller and hardtop with no motor, no trans, no diff or axles. All the wiring harnesses are hacked up from the big turbo build/custom ecu/wiring. I've got kirkey seats and a mostly intact interior. I basically need to replace all the wiring harnesses, install stock fuel lines, put abs back into the car, motor, trans, diff/axles, ecu, all front end body parts. I'm going to put a stock motor in it with upgraded springs and retainers, baffled oil pan, oil cooler, catch can, electrical cutoff switch, big radiator, good non-staggered tires, poly bushings in every arm, and upgraded coilover suspension suitable for the track. This will be a dedicated track car, built for track day fun. At this point i'm searching for a rear end wrecked car to source the majority or the parts needed for the car, once i find that i should be able to get this up and running rather quickly. I've had enough of these cars to know how to build them the right way with quality components, and i can do it rather quickly. This marks my 10th s2000. Attachment 78448 Attachment 78449 Attachment 78450 Attachment 78451 |
MOD LIST
(A work in progress) Chassis/Suspension/Braking Honda S2000 chassis fully caged and NHRA certified Ohlin DFV Coilovers Small Fortune Racing Gendron front sway bar Innovative 75A motor mounts Innovative 75a transmission mount Innovative 85a differential mounts Welded front upper control arm mounts SPC ball joints in front upper control arms Energy suspension rear control arm poly bushings 95a Prothane front control arm poly bushings 95a Hardrace front lower shock bushings Powdercoated front lower control arms Energy suspension tie rod boots Spoon front subframe X brace Spoon rear subframe brace Megan racing rear toe arms Megan racing front bumpsteer kit Centric solid rotors Carbotech XP10 pads Stoptech stainless steel brake lines front & rear Speed bleeders on all calipers Door and truck lock cylinders swapped to match AP2 ecu NRG hood struts Interior Kirkey seats Driver side Window Net NRG steering wheel NRG steering wheel hub NRG steering wheel quick connect S2Carbonworks carbon fiber center console cover Radio delete Exterior OEM Hard Top OEM AP1 Spoiler AP2 front bumper AP2 OEM style lip APR Carbon fiber front splitter CR fender turn signals AP1 headlights with orange diffusers removed Rolled Fenders front and rear Heeltoe Carbon fiber rear bumper single exhaust trim Engine/Powertrain 05 AP2 F22C Engine (80kmi) running on an AP2 ECU OEM Clutch with AP1 flywheel Rain8hr Valve cover mod Valve cover powder coated wrinkle blue with -10 AN bungs welded for catch can Intake manifold powder coated wrinkle black Throttle body powder coated gloss black Misc engine compartment brackets powder coated Mishimoto 3 row radiator K&N Intake Mishimoto oil cooler Moroso baffled oil pan Powder coated wrinkle black front timing cover Powder coated wrinkle blue front coolant hard line Izze racing air pump delete Izze racing EVAP delete Puddymod SAI block off plate Hondata throttle body gasket Skunk2 silicone radiator hoses Stainless steel full length clutch line Motorklasse 4.44 rear diff and yellowbox speedo calibrator Berk header back exhaust with vibrant resonator Throttle body coolant lines removed Evap lines removed AC Delete with CR AC delete button installed in dash |
Nice :thumbup:
I think you have a great project going. |
My two cents is that you should build it up as a spec qualified race car, perhaps similar to what Greg is running. That means you need to identify the class that you might want to run, find the rules, then build it to the specifications for that class. You don't have to race it, but ...
You can track a race car but you cant' race a track car. Tracking your car is a lot of fun, no doubt. But wheel to wheel racing is even more fun. Eventually you will want to do it. :rolleyes: |
Good luck on the project Jake. Should be excellent!
Subscribed.
Nice can't wait to see the build
Originally Posted by blueosprey90
(Post 24090758)
Jake - you can also make it a rental car and probably make up to $800 or so for each event you rent for.
That way, the car will earn you some money that you can use for its upkeep and also possibly pay for your track time. |
Originally Posted by A 2
(Post 24092568)
