New York - Upstate New York S2000 Owners All areas North of I-84 (Port Jervis to Putnam Lake) in New York State
need help for the transmission
Old 06-07-2017, 01:32 PM
tonyliubowen's Avatar
Default need help for the transmission
i living at buffalo. my 01 s2000right now have some trouble with clutch or transmission. does any guys know someone can help me do that near the buffalo or some shop? thank you verymuch. if you have any information please let me know. thanks five zero eight 733 8966. bowen liu.
Old 06-07-2017, 05:16 PM
shiv's Avatar
Looks like you are in my neck of the woods. Can you share some additional info regarding the issue you are having? May be something simple. That being said, I don't know anyone specifically in Buffalo that does s2k work. For something like that I would take it to Jake out in Albany. Bit of a hike, but worth it.
Old 06-07-2017, 05:17 PM
A 2
A 2's Avatar
Contact Jsenclosure (Jake). He is closest to you.
Old 06-07-2017, 05:19 PM
thanks for tell me but do you have some contact information for the jack? And where is jack's located?
Old 06-07-2017, 05:23 PM
for example. When you drive 30mph. And right now you select 4th gear. Then your foot move from clutch and gas. Then rpm and speed will be drop. At that time when the rpm during 3000-2000 the car will be have some vibrations and noise from the transmission. I go to shom shop check the car i can hear some noise coming from the transmission.
Old 06-07-2017, 05:34 PM
Conedodger's Avatar
How long have you had the car? Is this a new problem, or has it been going on for awhile?
2000-3000 rpm is too low to be cruising in 4th gear. Is it really a problem, or are you lugging the motor in too low a gear?
Old 06-07-2017, 05:36 PM
i just take this car back 2 weeks. That just the examples. Whaterer which gear. They will be same noise and vibration coming out.
Old 06-07-2017, 05:38 PM
A 2
A 2's Avatar
^ I'm with Mark. Also do you have the AC running?
Tell you what, meet up with Shiv and let him drive your car. As Mark says you are probably lugging the engine.
Old 06-07-2017, 05:48 PM
I already jack the car. And i can clearly hear the noise coming from transmission.
Old 06-08-2017, 02:14 AM
s200059's Avatar
My guess is its the diff and not the tranny. Those tranny's are pretty hearty until you track them (Am I Right SHIV), but the Diff's tend to be the week link whether you baby them or not.
Quick Reply: need help for the transmission
