rear bushing, front passenger LCA
As I mentioned in the track days thread, I recently found the rear bushing on my front/passenger LCA is blown.
The car behaved well for my second day at Palmer, but I took it up to NH this weekend for some rest and relaxation and it definitely wandered WAY more than it ever has in the past. I`m worried that it's more than just that one bushing at this point.
I thought long and hard earlier this year about whether or not I should sell the car. My first son is due in a couple weeks and it's tough to justify two cars. Ultimately, I decided I'd keep the S, but needed to start working on it myself instead of paying a shop. This would help keep costs down to a more justifiable level.
So - I need to replace my LCA mounts. While I`m in there doing the work, is it worthwhile to replace them with stock bushings? Is it time for an upgrade?
Car will still be primarily used on the street - is there an option better than OEM? Hardrace? poly?
LCAs will be done as a set of 4, but are there others that should be done at the same time? Uppers? Rears?
Very common problem. You can buy a used lca for about 80-100 and install it yourself. It's a pain and requires cutting out the existing lca but You can figure it out. I'd recommend just doing the one you need for a street car, it's costly to replace the bushings the right way all around the car.
Mike - I was about to reply and ask you to check with Jake and then I saw he had responded.
Maybe you can send him a PM to see if he has an LCA lying around. If not, he can guide you to where you can find one.
Spazzmeister
09-27-2014 10:52 AM
