**Official Desmond RegaMaster Thread**
Old 07-16-2018, 09:52 AM
  #771
jaor.s2k's Avatar
Originally Posted by ///MSC
Guys I've read thought pretty much the entire thread. Did some Google search as well. Am really not finding a solid answer.
question what us the colour code for the regamaster evo in original white?
just for a consideration, what are they in grey as well?
Many thanks for the help guys. Just want to get them spot on when I refurbish them next week.
typically wheel companies do not share color codes so its harder for replica companies to copy them.
Old 08-12-2018, 04:35 PM
  #772
marlboro's Avatar
  #773
marlboro's Avatar
^^^^ im almost sad to sell them
Old 09-07-2018, 03:24 PM
  #774
CarBoN's Avatar
There isn’t a color code, your not gonna get a code you can take to a paint shop
your best bet is to find someone local with a mint fresh wheel and take it to a body shop and have them scan it and try to match it
Old 11-04-2018, 04:07 PM
  #775
Rodd's Avatar
Found likely one of the only free and empty parking garages in the Atlanta area...
Old 11-10-2018, 06:35 PM
  #776
toreycarter's Avatar
New setup.
Old 11-14-2018, 04:47 PM
  #777
bouford's Avatar
looking good guys. my18 fk8 has joined the club
Old 11-17-2018, 12:37 PM
  #778
5ive6ix's Avatar
Can I get away with just a fender roll for a set of 17x8 +35 17x9 +38 on 225/40 and 245/45? I'm on stock height on my AP1. Keep finding conflicting info, some say nothing is needed, some say shave, tab Relocation, pull and roll.
Old 11-18-2018, 07:03 AM
  #779
justind's Avatar
Those are weird sized tires and will be way taller in the rear. If you want to get away with the least fender work and look the best you should run stock ap2 sizing at 215/45 245/40. With those offsets you will absolutely need a fender roll front and rear with a rear tab locate. You’ll also need to run some negative camber but nothing crazy. I would add that at stock height they may look aggressive and stick out, lowering would be recommended
Old 11-18-2018, 02:49 PM
  #780
5ive6ix's Avatar
Thanks for the info! That's the tire set the seller is including is the reason I was asking. But sticking to Ap2 sizes sounds like a good idea. I appreciate it man!
Quick Reply: **Official Desmond RegaMaster Thread**
