AP2 taillights conversion
didn't want to make this but I need help, does someone have a tool that can cut through metal that you can lend me? anyone done this and have experience and can help? I would much appreciate it, thanks!
I have read many DIY but I am not very experience with any kind of tools at all.
I don't own tools but the basic ones.
let me know! thank you!
on air cutter you'll be needing a compressor. Maybe only a rotary tools like a Dremel is all you need for cutting thin metal on a tight space.
you probably could get through it with a dremel with a diamond cutting blade. i was able to cut through the double layer of metal to do over fenders. i also have an angle grinder but they are a bit difficult to get into tight places. my dremel is on its last legs maybe someone else might be able to lend you one, or you can pick up a cheapo one from harbor freights. it probably will crap out on you after one run though.
dang...really wanna do this conversion but don't have the tool to cut :\
depending how much it cost to rent, you would likely have to buy the blades regardless. however you could buy one of these
http://www.harborfreight.com/profess...kit-40457.html
its a cheap solution, however they are not good long term and often times break down. i would personally invest in a little extra to get the actual dremel brand but if you are on a budget you cant be picky.
When I converted to ap1 tails I used a battery powered sawzaw to make most of the cuts then went back with dremel to make it cleaner. Ps don't forget the touch up paint for the metal you cut behind tail lights or it'll rust. Goodluck.
