Öhlins TTX
Öhlins TTX
I just found out that PSI is making an S2K fitment from the Ohlins TTX line. I believe it's the TTX36IL for the front and the TTX36 for the rear.
I was drooling over these at Moto GP and amazingly enough they're going to be available soon for our cars which I think is awesome.
PSI should have these in a couple months as a production unit but can be ordered now if you wish. They're right around $4500 for the dampers, spring perches and the machined clevises for our car, add springs, top hats and you're good to go.
Front 5lbs 7.4oz less spring
With spring 7lbs 11.3oz
These are 2lbs 2oz lighter than SRC's and 3lbs 9oz lighter than KWV3 CS's
Rear 5lbs 2.6oz less spring
With spring 7lbs 8.4oz
These are 2.5lbs lighter than KWV3 CS and .5lbs lighter than Tein SRC's
4500 for the dampers, just add top hats and springs.
Springs will run you roughly 360 and 500 for AST top hats.
The Ohlins pinmount is 18mm which is the same size as most pillow ball style top hats.
I think you can get 2.5 or 2.25 inch springs perches and I went with 2.25 800lb front and 700lb rear spring and no helper or tender springs.
Yea I wasn't a fan of the way the compression adjuster is on the V3's either and it's really nice to just have to go to one place for both adjusters on the Öhlins.
They make them for their coilovers which will fit others as long as the pinmount is the same size as theirs or if your current misalignment sleeves are 18mm OD on the bearing side or you can machine your own misalignment bearings.
